Question about Sharp Televison & Video
I have connected the tv to cableand I can only recieve channels 2,4,5,9 & 13. How do I set up the tv to receive the remainder of the channels? Thank you
  • 604 Answers
Do a channle auto scan, you need to select CATV in order to scan for cable channels. after the scanning process, all the channels you can get should be on your set.
Posted on Mar 20, 2011
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
Is this tv capable of receiving digital signal from directTV
The direct tv reciever has a coax output that will send a signal to channel 3 or 4 that any older telivision can recieve...so the answer is yes. You obvously need a direct tv reciever to watch direct tv on any telivision.
Nov 26, 2009 | RCA E13319 13" TV
Can only receive cable channels 2 through 13;
Turn the unit off, push the setup button 3 times. Press the seek left/right to switch between cable / antenna tuner modes. When cable is selected, press the channel up/down to switch between cable modes. When the unit turns back on, it will rescan for channels.
Aug 04, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
How to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
May 12, 2008 | Televison & Video
Only goes to channel 13
It probably has to do with a setting in your menu. Usually it is the antenna category. Change it to Cable or CATV.
Mar 18, 2008 | RCA T19408 19 in. TV/VCR Combo
Need help viewing all public television channels
Your TV is set for standard broadcast. You need to go to the set up menu and change from antenna/normal to cable mode. In standard broadcast mode you receive off the air programs 2-13 vhf and 14-83 uhf. In the cable you receive 2-13 and cable channels 14 -125 if the set is not too old. When cable channels first came out some sets would just cover 14- 36 or 14- 47 or 14-66 etc. The newer sets cover the now standard cable channels 14-125. Hope this helps you Stargazer
May 25, 2007 | Quasar SP-2725 27" TV
Televison & Video Logo
161 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
