Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg tromm wm1812cw error code oe - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
SOURCE: My LG TROMM (WM1812CW) does
check out lg's site page 21 or 23 and it will tell you what the error code is as well as how to fix it. http://us.lge.com/download/product/file/1000000200/WM1814CWowners.pdf
Posted on Jun 01, 2008
SOURCE: my LG Tromm washing machine
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Posted on Oct 10, 2008
onthejob5130
  • 640 Answers
SOURCE: LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Posted on Jan 30, 2009
  • 3 Answers
This code means that something is blocking either the water drain pipe, pump filter or the pump itself. I had the same problem and removing the filter (as recommended by LG) did not help. It turned out I had a piece of debris stuck in the pump propeller itself and consequently the water would not drain and the wash would not finish, prompting the error. This is what I did to fix the problem.
1. I removed the cover on the left bottom corner and the removed the filter and unhooked the little rubber tube (drain).
2. I removed the pump cover (lower left corner of the washing machine) and unscrewed 3 screws holding the pump from the front.
3. I disconnected the power supply and removed the back panel (attached with 4 screws)
4. Disconnected the two hoses (one black, one gray) from the pump.
5. Disconnected the power supply to the pump (I had to cut a plastic tie holding the connector in place in order to bring the connector closer so I can disconnect it).
6. Removed the pump by pressing a little tab that was holding it from the back.
7. Once I removed the pump from the washing machine, I took three screws out of the pump motor, gaining access to the propeller. This is where I found a little piece of plastic. Apparently propeller couldn't spin because of that obstruction.
8. I put the pump back together and attached the hoses. This is easier to do when you have the pump closer to the back opening of the washing machine.
9. I then connected the pump power supply connector, locked the pump back in its place and replaced the screws.
The total repair took less than 45 minutes. The hardest part was to remove and replace the drain tube springs, because I did not have the right pliers (You need decent size pliers or plenty of strength in your hands to squeeze the metal bands).
The tools you need for this repair are:
a philips and flat screwdrivers, large pliers and a sharp knife (to cut a plastic tie)
Posted on Mar 10, 2009
rdrsp
  • 85 Answers
SOURCE: lg tromm wm2277hw rinse spin error OE
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Posted on Oct 26, 2009
How to fix an error code "CE" on my wm1812cw lg tromm front loader5
See if the top will lift up, if so there will be a code and test sheet in there that will lead you to fixing the problem. Very easy to follow.
Jan 06, 2016 | LG Washing Machines
My tromm LG front load washer is flashing OE, what is it.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Jul 19, 2011 | LG Washing Machines
The washer is displaying an OE. How do I fix this?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Getting the OE error message on LG Tromm
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
I have an LG TROMM wm1812cw washer. Out of the blue the machine will not spin or drain. It has given an an error code OE
Sep 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Jan 04, 2009 | Washing Machines
Washing Machines Logo
259 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
