Question about Garden
Pull rope came out and stayed - Garden
  • 604 Answers
On most brands you can go to the dealer and buy the replacement spring and cord assembly, if you don't have someone that sells this blower in your area you may be able to get the parts from Sears Parts www.sears.com/parts they can get parts for most every brand.
Posted on Mar 19, 2011
How do I replace a starter rope on a troy built 4 cycle weed eater model no. tb685ec
Remove 4 screws that hold starter to housing, remove handle by cutting rope, notice how rope is wound and mark arrow on spool for direction, from drawing looks like there is a compression ring holding the spool in place, let tension of spring by allowing spool to unwind, Remove this ring very carefully to prevent damage. Remove spool carefully and let spring stay in starter housing. Rewind rope install in starter housing install compression ring wind cord in spool three turns pull through rope eyelet and install handle.
Apr 12, 2018 | Troy Garden
Replace the starter rope
you have to remove the recoil from the engine. you will see where the previous rope was tied off. remove old rope and turn spring assembly until tight then back off 1 complete turn. after tying your rope, put through the passages until it comes out the housing hole pull rope all the way through and tug on it to make sure that your knot stays. holding the rope let it recoil in slowly. pull on rope a few times to make sure action is smooth. install handle and adjust rope to proper length
Apr 08, 2014 | Toro Power Clear 221QE Electric Start 21...
Broken pull chord
Remove recoil assembly from top of engine. Observe recoil wheel and find knotted end of rope in wheel, Observe direction of rope wrapped around wheel, cut knot off wheel end of rope remove rope. Rope purchased by the foot at mower repair shop. Feed new rope end into hole in recoil wheel wrap around in correct direction, feed rope thru recoil cover, remove old rope from handle, feed new rope thru handle to proper length, Knot rope to stay in handle.
May 14, 2012 | Toro Power Lawn Mower
Recoil pulley assembly keeps binding. Rope stays in pulley, but won't retract. Must remove motor housing , loosen 3 pulley hold down guides, & uncock the pulley. spring tension on recoil is fine....
Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
Aug 05, 2011 | Garden
Replacing a pull string on a lawn mower
This can be tricky depending on the brand. Most pull start systems will have 3 or 4 bolts on the fly wheel- puppeteer cover.when you take the cover off, it should all stay together. It will have a plastic wheel inside that the rope winds aroundand in the center of the wheel should have a bolt. Remove the bolt and remove the plastic wheel, but be careful it will have a wind up spring, but most newer models have an enclosed spring.you should see a hole in the side for the pull rope. Insert the rope through the outer sheild first and thenthen in theslot of the wheel(kinda like stringing a yo-yo) then insert the end of the rope on the side of the wheelwheel in the hole, and tie a small tight knot in the rope so it won't slip through.then put the wheel back in the shield, and wind up the rope around the wheel. You should feel the spring tighten up. Don't let go of the spring tensioned wheel and rePlace the center wheel bolt. The handle should sticking out the sheild hole. Now replace the assembly on the mower. Some models you have to wind the spring and hold it tensioned with a wire while you replace the sheild, this tricky. But most wind upwhen you pull the rope out. So when you release the rope the spring will wind it back up. Good luck this task can be tough for first timers.
Jul 31, 2011 | Briggs & Stratton Garden
The rope on my generator gets stuck as i pull to turn it on
Assuming the rope stays on the internal pulley, it is NORMAL for the rope to require great force at points in the cranking cycle (once per revolution of the crankshaft). These are the compression strokes and the force is MANY times the initial pulling force. If the rope returns easily, then the starter assembly is probably normal. It takes a strong arm and fast movement to start the enginess via pull rope. Some units have a compression release to ease this a bit.
Mar 22, 2010 | Electrical Supplies
The starter pull cord has pulled off.
EASY,REMOVE TOP COVER OF ENGINE THAT HOUSES ROPE ASSY. LOOK UNDERNEATH PLASTIC PIECE,CUT THE KNOT OFF THAT COMES THROUGH HOLE AND PULL AND EXISTANT ROPE OUT. OK, GET NEW ROPE AND HANDLE TOGETHER,THE END THAT IS OPPOSITE FROM NEW PULL STRING HANDLE YOU ARE GOING TO USE. CAREFULLY WIND UP ROPE HOUSING NICE AND FIRM JUST BY WINDING IT UP WITH HAND IN AS IT SITS IN TOP COVER. WHEN YOU THINK IT HAS ENOUGH TO PULL ROPE IN FEED END OF ROPE IN HOLE AND IN CHANNEL OF ROPE HOUSING,THERE IS A SMALL HOLE TO LINE IT UP WITH,WHEN SEE THE ROPE END FEED IT THROUGH THAT HOLE NOW. MAKE TAKE ANOTHER SET OF HANDS OR A WEDGE TO STOP RETRACTING OF SPRING. PULL ROPE THROUGH AND TIE A DOUBLE KNOT AT END SO IT WONT PULL THROUGH. SLOWLY LET IT PULL ROPE IN,THEN PULL ROPE BY HANDLE FULL LENGTH TO ENSURE ALL KINKS ARE OUT AND IT PULLS BACK IN LIKE IT SHOULD.
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
