Question about Creative Labs ZEN V Plus MP3 Player
Am playing with the screen brightness key...inadvertently hit the execute key at 0 % brightness.Needless to say,my screen is now dark.Am muddling with it...ask for solution. Or can I use the default menu and work from there by counting the menu order?? P.S.all other components work properly(MP3,radio,photo)
  • 604 Answers
You can do a reset to get back to factory defaults but you ay want to save your files somewhere before you do that, otherwise you may lose all of them. there should be a system reset button on the device, you can also try just taking the batteries out and leaving them out for a couple of minutes. If you have the manual to the device, that may help you locate the way to reset it for sure.
Posted on Mar 20, 2011
Screen brightness adjust key
There is no key to adjust the screen contrast on the TI 30 XII S. You can try to reset the calculator by pressing 2nd 0.
It is possible that you have kept this solar-powered calculator too long in the dark. Give it some light.
Jan 01, 2014 | Texas Instruments TI-30 XIIS Calculator
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
LOOKING FOR A REPLACEMENT SCREEN
Darken the screen and either move the lid forward or backwards. Laptops have Liquid Crystal Screens and moving the lid backwards or forward will give the screen a different look.
If you need to adjust the brightness of the screen it is controlled by keys on your laptop. Most times to darken the screen you will have to hit the FN, CTRL or ALT key and hold it down while you hit the key that corresponds to the screen darken key. On some computers (even on my laptop) it will be the down arrow key, so i would press FN+the down arrow key. Remember to hold the first key down while you hit the next key. The icon used for most times to denote the brightness or darkness looks like a circular sun or a washer that goes on screws.
Mar 22, 2012 | Computers & Internet
Monitor to bright
Decreasing Screen Brightness (FN+F9)
Press and hold the FN key, then hit the F9 key to decrease screen brightness.
Increasing Screen Brightness (FN+F10)
Press and hold the FN key, then hit the F10 key to increase screen brightness.
Mar 21, 2012 | HP Compaq nc6230 Notebook
Disply screen has very little brightness
It could be a couple of things. The first is that screen brightness automatically dims when you go on battery, which is to save power. The second is that the brightness setting got changed inadvertently.
There are two function keys at the top of your keyboard that control screen brightness...one turns it up, the other down (they generally have a small circle with rays coming out...one circle is empty, the other filled...sort of like a sun and a dark sun). Hold down the Fn key and press one or the other of those function keys and see if that makes a difference in your screen brightness.
If that doesn't help, you may have a faulty LCD screen.
Hope that's helpful.
Jan 20, 2011 | HP Pavilion zd8000 Notebook
Screen is so dark. Is there a way to fix the settings
Hi:
If your screen is just slightly dark, you can increase the brightness by holding down the function key, and repeatedly hitting the brightness + key, which has a picture of a shiny sun on it.
If that doesnt help, you could have a LCD back light or inverter fail, and you can verify that is the problem by hooking up an external monitor to your laptop, and check to see if the picture quality is good.
Nov 10, 2009 | HP Compaq nc6320 Notebook
How to adjust the screen brightness form dark to bright
ok bottom left hand side of keyboard there is a key with fn on it hold this down along with other blue keys that have like little suns on them this is your brightness keys
Sep 06, 2009 | IBM Lenovo ThinkPad X40 2371 Notebook
Screen is dark
Is this a brand new computer? Was it displaying properly before and just suddenly started showing up dark?
Most laptop monitors have a brightness control. It is possible that yours may have been inadvertently turned all the way down (it can happen accidentally). It is usually accessed by a function selector on the lower left side of the keyboard in conjunction with a function key, like F7, F8, F9, etc... you should check your manual first to be sure.
If that doesn't help, then it is possible the backlight for the LCD screen has gone dead. Those can be replaced by authorized service centers.
Dec 29, 2008 | Everex StepNote NC1500 Notebook
Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
No visual display
Function F7 will enable the external video monitor connection and will toggle between the screen, the screen plus external monitor, and the external monitor only. Try hitting function F7 and see if that helps. Also there is a small switch that is activated when you close hte lid to turn off the display when the lid is closed. make sure that this little switch is not stuck.
Dan
Mar 21, 2008 | IBM ThinkPad T23 2647 Notebook
Creative Labs ZEN V Plus MP3 Player Logo
128 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
