Question about Electronics ESD 767 Radar Detector
767 model How do you set it up? - Electronics ESD 767 Radar Detector
How do I set the date & time on my UA-767 plus?
Hi Carol.
not sure if this will help you out,but go to this link and it will show you the manual,thats if it is what you are looking for.
LifeSource UA 767 Plus Instruction Manual
Jun 15, 2018 | The Health & Beauty
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
Where can I get an instruction manual for the UA-767 plus
You can download the User Manual (PDF) for the UA-767 Plus Digital Blood Pressure Monitor by clicking here:
http://www.aandd.jp/products/manual/medical/ua767plus_en.pdf
You can also download product brochures and other info here:
UA 767 Plus Personal Lines Medical Products
May 05, 2017 | The Health & Beauty
How do you set the timing on a Singer Coonfidence Stylist 767?
Take it to a machine repair shop. You won't have the tools or the settings to set timing.
Oct 03, 2014 | Singer Sewing Machines
Filling and bleeding the 767 handpump
where are put the oil, in my 767 hydraulic hand pump, knockout punch..
Dec 23, 2010 | Greenlee 7646 Hydraulic Punch Driver
I have a Mr. Steam unit installed in my shower room. When i turn the steamer on it sounds like it is working and the lights are on but no steam coming through!!
Hi I am with Mr. Steam Tech Support please call 1-800-767-8326 and ask for tech support we will also need you model and SN that are located on your steam unit
Nov 27, 2010 | Mr Steam Hardware & Accessories
My lifesource ua-767 displays err 3 is it the cuff or the machine
Turn it over tap little black gauge above battery cover with fingers turn on, err 3 code normally resolved.
Sep 25, 2010 | Lifesource Ua 767 Blood Pressure Monitor...
INTERCHANGE MODULE
I'm gonna go out on a limb here and assume you are talking about the band modules, right? If so it will accept some in the 6m,2m,and a couple of the 70cm bands. The model numbers I know it will accept are as follows: FEX-767-2,-6,-70A and -70B. If your module is one of these they are interchangeable. BTW, all of these modules are presently discontinued I'm sorry to say. Hope this helps!
Mar 27, 2009 | Radio Communications
I need a c adaptor model 090-02180-13
The AC adaptor that you needed is Astar right?
Please provide the model of your TV. Call me at 323-767-6030.
Jan 18, 2009 | Astar LTV-19BG TV
Electronics ESD 767 Radar Detector Logo
26 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
Jason
Steve
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
