Our cable company has upgraded to digital channels. This tv has the right equipment in it and should find the digital channels but doesn't. When I first did a digital channel search it grouped channels into DC channels- 1 through 9 and so on and so forth...you couldn't figure out which channel tho you were actually on. Then when I called the cable company I did a all channel search and it just came up with basic channels and now it says that the digital channel search isn't available. What can I do to get the line up of the channels correct and be able to do a digital search again? Do you have a manual that explains this? Sanyo Model DP19647
  • 604 Answers
The cable company switched to digital just like everyone else, but that should not effect your viewing, they convert the channels back to basic cable so you can see the without having to do anything. If you want to watch "over the air" digital tv you need an outside antenna and television that can recieve digital signals, or put a digital convertor box on your set, but none of this makes any sense if you have cable because you are already getting the same channels over the cable.
Posted on Mar 20, 2011
  • Jean Parks
    Jean Parks Sep 30, 2014
    No they do not convert the channels back to basic cable. in Murphy N.C. They say by years end all cable will only be digital.
  • Jean Parks
    In2015 all signals will be digital. I also got the "Not Available" message and we somehow after hours of playing with the set, found a channel that opened up a yes no download bar for digital. We received the digital stations happily but, sorry, we don't know how we did it.It was almost accidental.
The electricity went off last night and now my tv doesn’t get any channel from the antena. I already scan for channel but the tv doesn’t pick any channel
unplug the tv and let it sit for about 5 minutes.
then plug it in and follow the user manual's steps to re-program the channels.
if that fails, then contact a repair facility for help. not knowing the make or model of equipment makes further guidance difficult to impossible.
Mar 25, 2018 | Televison & Video
I have a Model 42hdt51 TV, serial no. V5B006400. My last cable card upgrade was March 14 2009.
You should contact Customers' Service of your undisclosed cable company.
Aug 12, 2015 | Televison & Video
Digital channel mix up
your cable company is moving the channels around. they are doing a major upgrade
Nov 19, 2009 | Toshiba 32WLT58 32 in. LCD Television
What is a cabel card
A cablecard is the size of a credit card use to view or record digital cable channels on a digital recorder,personal computers and tv s without the use of outside equipment like (stb) set top box provided by your cable company, below is a picture of one hope this helps.
Aug 12, 2009 | Zenith Z37LZ5D 37 in. LCD TV
Limited cable channels
There isn't a software upgrade available for your TV yet. So, the TV has the latest software right now.
I would try making the TV search for more channels.
Press Menu on the remote,
go to SETUP,
then go to CH SETUP,
then make sure the AIR/CABLE option is on CABLE,
then go to CH SEARCH and select " Analog & Digital Search Start ".
The new channels should show up after the scan is done.
If this doesn't work, the TV may need some type of new converter/cable box from the cable company.
If you need a copy of your manual, you can go here:
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=lc37sb24u&s_func_disp_id=27&x=37&y=10
May 26, 2009 | Sharp LC37SB24U 37 in. LCD TV
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable. When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive. Depending where you are and the type of antenna you use you probably could pick up some digital channels. Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Sep 18, 2006 | RCA F27628 27" TV
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
