Question about Dell Dimension 5100 (D51L1) PC Desktop
Dimension 5100 wont start up .power led on MB is on changed mb.shorted out test done fan went.nothing else.what next ???
  • itswallace1 Apr 02, 2011
    thanx tgvern awaiting arrival of psu will put that inandtry my luck cheers
  • 281 Answers
I have seen more than a few of these (Dimension 5100 series) die due to mainboard issues. If you haven't done so already, take out everything you can, (add-in cards, modem, disconnect hard drives, CD drives, etc.) Try to restart. If you get it to boot, you can add in one item at a time, and realize that when it won't start that is probably the culprit.
Next, If you have a second PC that has known good RAM of the same type, I would swap that out as well. Then try to boot with just video, Mainboard and RAM. If you see any blinking lights/sounds/etc. then report that on here as well. There are beep codes and on Dell's there are light error codes.
I you do happen to have a spare CPU, you could swap that out as well if you can, but I would not bet that is the problem as they are pretty durable for the most part.
If none of these comes up with a booting PC, it could be your replacement mainboard is bad.
Posted on Mar 20, 2011
My computer won't power on. Tested power supply by shorting green to black wire. Found PS fan seized. Replaced fan. Worked with pins shorted.
Admittedly, this could still be your power supply (PSU). Perhaps you did attach the 24 pin motherboard (MB) connection to a tester, but since the post does not specifically mention this I presume you may not have. Forgive me if that was done.
Assuming the test was only jumping the 24 pin connection verifying that fans kicked on; my guess would be that the PSU still functions. However, it may no longer be producing enough juice to power the PC.
If you have not done so already, I recommend testing the power supply against a tester to verify that you are getting enough voltage to power the motherboard.
Oct 24, 2015 | Dell Inspiron 531s Desktop Computer
Nothing happens
chk the 4 LED on the back of the computer labeled ABCD, and let me know the status?
Jul 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
My dell c521 wont start i have green power light on and number 4 is light up green the fan is also running high
Pretty Much General basic troubleshooting.
  1. Disconnect all external connections except the power, see if error changes. If it does, connect items 1 at a time till issue is isolated
  2. Remove all Expansion cards, see if any change
  3. Disconnect all drives from MB and power supply, see if any chage.
At this point if nothing has changed, replace the motherboard.
May 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wont start
If you see the red LED then the Power supply is ok. Sounds like there is an issue with the Motherboard, Either a cable got disconnected, or a bad board.
Dec 31, 2009 | ASUS P5GD1-VM Motherboard
ATX Bestec 1956F Power Supply Failure
sounds like your power supplie has not been switched on by *********** board.the fan will not turn on until power supplie is turned on by mb.as far as what is wrong there are several things i can think of.i would try resetting bios. It sounds like your power supplie is working and your motherboard could have a short.but i have no way to be sure without testing. I can however tell you how to perform a test on your power supplie.unplug the 20 or 24 pin connector from your mb. look for a green wire,and then locate the grey one.short these two together(you can use a paper clip or something).if it dosnt power up. your power supplie is bad.also do not short any other wires,and only touch the grey and green for a few seconds as this is not how it was intended to be powered on.
Mar 03, 2009 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
DG31PR Won't Boot
you ight have a BAD CPU, try checking it out on another pc or friends pc.
Jan 08, 2009 | Intel DG31PR Motherboard
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
No Power up on depressing On/Off button.
Sometimes if the CPU is overheatign it will power down to stop the cpu from buring out. A power suppluy just supplies power to the motherboard and that's it. If the CPU gets hot it shuts down and wont start till it cools down again.
Nov 04, 2006 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Dell Dimension 5100 (D51L1) PC Desktop Logo
43 people viewed this question
Alun Cox
