I have a Maytag Performa MTW5740TQ0 washer that won't fill on cold. I don't have hot water hooked up to it, 1 just have cold water run to it. When the water temp selector is on "cold" nothing happens, I can hear the the valve activate and a humming noise. When I change it to "cool", "warm" or "hot" cold water starts to fill, on all three settings. I have already replaced the water inlet valve with no luck.
    Sergeant:
  • 170 Answers
Check your lines may have them mixed up...good luck
Posted on Mar 20, 2011
Maytag Performa model mtw5740tq0: won't fill up with water
There is an exit hose behind your washer, it has to be maintained a particular height (approx 30inches from ground) before it goes into the standpipe in the wall. The gap in the pipe should not be a tight fit. Another thing that could have occurred is that one of the pipes underneath the washer has come loose; you just have to check these things out. But plug off the mains socket first!
Feb 10, 2010 | Maytag MTW5700TQ Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
I just rented a trailer, and they only have cold water hookup.
yes it must be capped, you can find one at any hardware store.
Oct 17, 2009 | Maytag Performa PAV2200
Warm water filling up washer, with no hot water hooked up to wash
exactly
it will maintain 60 degrees but cycling hot cold
thermistor
Sep 29, 2009 | Maytag Performa PAV2200
Maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Aug 10, 2009 | Maytag Performa PAV2200
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Washing machine will not fill with water maytap performa - will not fill w/ water - keeps running. Solutions?
water valve on back bad?try it on cold then cold warn then hot and see if you get anytihing,let me know more-mike
Sep 27, 2008 | Maytag Performa PAV2200
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
