Question about Dryers
The dryer does not "dry"
Its probably not your dryer,have you checked your dryer vent hose or your vent pipe to see if there is blokage from the lint.some home's the vent pipe runs vertical to the roof top and the lint after time clogs it up.even if it runs horizontal it still need's to be checked this happens all the time you can use a higher power shop vac to clear the vent pipe,or you might have to get a small 25 ft drill snake and go from the roof down.
Posted on Mar 20, 2011
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
What setting for drying clothes takes the shorties time
make sure your filters and around your drum is clean that is a reason for clothes taking long to dry
Oct 13, 2014 | Dryers
Model DLE5932W is prompting "check
Thank you for your question. This is a standard feature on almost all new dryers. There is only one filter in your dryer and that is the lint filter. The reason that the Check filter light appears either before your start the dryer or after it finishes is to remind you that you should in fact clean the filter.
Having a clean lint filter is very important, it decreases the amount of time it takes to dry clothes and it prevents lint from clogging the dryer vent.
If you are having a drying issue it is possible that you could have a plugged dryer vent. But if everything seems to be working correctly then this serves as a reminder only.
Aug 24, 2011 | Dryers
Takes longer to dry clothes
Most of the time when your dryer is taking longer and longer to dry the clothes it is due to a clogged dryer vent. Just take the vent off and clean it. If the dryer cannot vent it cannot circulate the air inside the dryer
Jul 15, 2011 | Amana Maytag Dryer Lint Filter Screen...
LG Dryer Model # DLE 2050 W is not drying. It is getting hot but clothes remain wet even after 2- 1 hour cycles. The information panel is blinking with a message that says "FLOW SENSE". The...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Feb 14, 2011 | LG Dryers
I have a whirlpool dryer and the heating eleiment is getting hot but the dryer inside is barley warm
Inside of the dryer gets warmed up when the drum rotates as there is circulation of air. Hope your clothes are drying. If it takes long time then clean the screen filter as it gets clogged with the flint from clothes. As a matter of routine clean this filter every time you use it before starting the drying process.
Sep 16, 2010 | Whirlpool LER4634J Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Laundry taking too long to dry!
1. Make sure the filter is clean. A clean filter allows for proper air circulation in the dryer.
2. Make sure the rear dryer vent is clean. Move the dryer, unplug it and remove the rear vent hose and clean out any debris from the vent, in the hose and any debris in the outside vent.
Over time, these things get clogged and reduces the air circulation in the dryer, causing it to take longer for the clothes to dry.
Please let me know if I can be of further assistance to you.
- Jim
Feb 14, 2008 | Dryers
Dryers Logo
391 people viewed this question
Top Dryers Experts
