Question about Maytag Ovens
Trying to change Maytag Gemini from natural gas to Propane. Have orifices, but no diagram of where they are located.
  • 604 Answers
Take the covers off the burners and look, the jets are near the burners, small wrench to turn them out and replace with the other jets. the oven is a different story, and depending on you model may not even have jets that can be replaced, rather you adjust the one jet that's in there by turning it with a wrench (you should have gotten a book that helps with this)
Posted on Mar 19, 2011
Convert lp natural gas
To convert a lincoln LP gas oven to a natural gas, you actually first of all need to buy from the supplier an orifice ment for natural gas and change. The difference in the orifices could be in the size of orifice aperture.
The orifice i'm talking about is located in the burner assembly. you got to dis assemble the burner so as to get to it.
After that you need to adjust the main gas manifold when the oven is on. The adjustment must be done such that the pilot flame is not yellowish
Jan 28, 2014 | Lincoln Ovens
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
Need to kmow location to change orfis to change from n gas to lp
when changing a stove or oven from natural to lp the orifices would be inside the burners or under the upper deck of the oven also you would also need to flip the cap around on the gas regulator as well if you have a model number i might be able to show you a schematic of how to locate your orifices on most units the upper deck flips upwards in order to provide you access under the burners this is where the orifices are usually access As a matter of fact I have 9 today that I will be personally switching from propane to natural not only amanas either fun day for me planned if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to continue helping people in similar situations in the future Thanks again Rick
Apr 29, 2011 | Amana Ovens
I will soon need to convert a 1993(?) CALORIC Kitchen Range back to Natural Gas from LP. When I installed it, NG was not available, so the propane company guys converted it to LP. I was not here to learn...
First check the regulator valve on the back of the stove. Chances are it is a dual purpose valve and once you are ready to do the converstion.. you simply will move the lever or change the setting from LP to NAT.(obvisouly before proceeding you need to have the fuel supply turned off to the appliance)
Next check under the range lid or on the back of the stove for the spare NATural gas orifices.. when they changed it out for you there were two scenarios.. the range (most do) came with a set of LP orifices..and they simply changed these out on each burner supply including brolier/oven. (orifices are interchangeable nozzles that are threaded into the supply gas burner)
If they had to swap out the regulator chances are they would have given you the one that came with your stove.. However I am fairly sure the regulator is a dual purpose and you simply need to change the setting from LP to NAT.
DO NOT DO THIS WITHOUT CHANGING OUT THE ORIFICES FIRST.
If you cannot locate the spare orifices/spud/nozzles (they are called all of these) on the stove itself you will need to buy a set. A good appliance parts store will be able to help you with these.. again.. you will need one for each burner/burner supply.
If you can locate the range manual it will have instructions on how to do this.
Chances are your Natural Gas company will be able to help you with this.. especially if the regulator is dual purpose.. even if you can't find the orifices they are inexpensive.. fairly standard and easy to acquire. Usually just called a "conversion kit".. it will just consist of four or five small threaded 5/16 brass nozzles/orifices.
The installation is pretty straightforward. Again..a good appliance parts store may recommend a service company...and if your not familiar with diy repairs on a gas appliance.. a 50 to 100 dollar service call is well worth the money.
Best of luck to you!
Apr 11, 2011 | Ovens
Natural gas to propane?
You have to get a converter for propane. You can call any hardware store in your area. Hope this helps you, if not, you can call me. :>)
Aug 13, 2009 | Maytag Ovens
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Ovens Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
