Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
When I open the top to replace the ink cartridge, the ink does not go to the middle so I can remove the old cartridge.
Turn the printer on before changing the ink cartridge. The mechanism will only go to the middle if the printer is turned on.
Posted on Mar 20, 2011
HOW DO I OPEN MY CANON PRINTER TO GET TO INK CARTRIDGES
Lift cover. Ink cartridges will appear in the middle and you can remove old and replace them with new ones.
Oct 26, 2013 | Canon PIXMA MP600 all-In-One InkJet...
How to reinstall new ink cartridges
Open usually in the front in the middle there is an opening pop it open have it on ink cartridge should move to the middle pop the clips and slide old one out gently slide new one in
Apr 10, 2012 | Canon Office Equipment & Supplies
How do I intstall a black ink cartridge in a hp desk jet 5550 printer?
Follow these steps to install the cartridges. Step Example
  1. Make sure the product is on.
  2. Open the top cover. Wait until the carriage moves to the center of the product and is idle and silent.
  3. Open the cartridge latch.
  4. If you are replacing the cartridge, slide the old cartridge out of its slot.
Figure 6: Open the product and remove the old cartridgec00160484.gif Remove a new cartridge from its packaging, and then carefully remove the plastic tape. Hold the cartridge so that the copper strip is on the bottom.
CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 7: Remove the protective tapec00160485.png
  1. Slide the cartridge firmly into the cradle. Make sure that the copper contacts of the cartridge meet the copper contacts inside the printer.
  2. Press down on the cartridge latch until it snaps closed.
  3. Close the top cover.
Figure 8: Insert the new cartridgec00160486.gif
Nov 03, 2010 | Office Equipment & Supplies
How to replace ink
Hi Good day!!!
to change your ink cartridges follow this steps
1. Switch on your printer by pressing the power button.
2. Open the cartridge access door and wait for the cartridge carrier to move to the middle.
3. Press the tab in front of the empty ink cartridge and remove it from the slot.
4. Remove the plastic wrapping from the replacement ink cartridge and take off the orange tab. To do this, carefully twist the tab and snap it off.
5. Place the new cartridge into the slot you removed the old cartridge from; then push it down until it clicks into place. The label must be on top of the cartridge, and the plastic tab should be at the back.
6. Close the cartridge access door, and your ink cartridge will be ready for use.
Don't forget to vote thanks!!!
Nov 02, 2010 | HP Officejet 4355 All-In-One InkJet...
I have difficulty removing the old cartridge, and I don't want to force it and break the printer. What is the best technique for removing the cartridge?
Make sure the printer is on. Once you open the cover, the ink cartridge carrier automatically goes to a loading position where it moves to the middle. Then, you can replace the cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the new cartridges. Close the cover. Plug the printer back to power source.
Sep 24, 2010 | Lexmark X4270 All-In-One InkJet Printer
"Print carrier stall"?
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
Dell Printer A940 Hardware error
Back to Top
» Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  8. Press Select.
Back to Top
Jul 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer 964
  8. Press Select.
Back to Top
If this information has not solved your issue, then you have to contact Dell. They may need to replace the printer.
Jul 02, 2009 | Dell Photo 964 All-In-One InkJet Printer
Do not know how to replace ink jet cartridge
open panel above printer paper cartridge should move to the middle pull towards you and replace old with new one the same way old one came out
Sep 21, 2008 | Office Equipment & Supplies
Lexmark x2480
what do i do when i lift the cover of the printer and the cartridge does not slide over and therefore i cannot change the ink cartridge?
Feb 22, 2008 | Office Equipment & Supplies
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
41 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
