Question about GE Spacemaker JVM1640SJ Microwave Oven
I was defrosting frozen spinach in a plastic tub for ten minutes and inadvertently had it on full time! Spinach caught fire and tub melted totally down! Nothing is working on the microwave now. Is it repairable? Doesn't look like it!
  • GE Master
  • 6,771 Answers
The microwave oven is not worth sinking the money into, the interior paint has probably burnt off, door and switches will probably need replacement, the turntable plate, and additional parts "turntable motor" and other major parts are suspect, replacing the microwave oven in my view is the safest alternative.
Posted on Mar 19, 2011
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
My freezer is icing up and water is dripping from the ice. I'm having problems closing the door as a result, and removing frozen food.
Try this, If it is an upright fridge, remove the flont lower vent grill. Ten to one the coils are covered with dust and cobwebs. Not implying anything, mine was horrible. Vacuum all the stuff that has accumulated untill the coil is nice and clean.. Unplug the unit so you don't get into the moving fan blades and don't reach into the space, There are hot componants. Good Luck, Ned
Aug 23, 2009 | Microwave Ovens
GLMV168 Frigidaire over-the-counter microwave oven. My wife inadvertently let it run for about a minute with steel utensils in water in a glass jar along with plastic dishes. She says there was a small...
Hello Robert, I am happy to assist you. Let's try resetting the microwave by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the unit on. If the issue persists, then based on the symptoms you are describing, it could possibly a faulty fuse or the main control board. If the instructions above do not solve the problem, I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 11, 2013 | Frigidaire Mid-Size Microwave
How to defrost solid frozen thick steak
you can set your microwave to defrost or 50% power to defrost steak
if this was helpful please give it a thumbs up to help others too
May 19, 2011 | Microwave Ovens
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
Is it safe to use a microwave if some thing inside of it caught on fire?
Its no problem at all so long as it still runs normally. Only problem, is the smell will annoy you for a while. Give oven a good wipe down with a good cleaning agent.(I'm assuming the fire didn't get out of control).
Sep 27, 2009 | Microwave Ovens
Roper microwave caught a paper towel on fire.
Why is this even a question?
Of course a paper towel can get hot enough to catch fire in a microwave. In addition, anything not specifically identified as microwave safe can melt, deform, crack, chip, spark, catch fire, explode, etc...
This is not a microwave problem.
Mar 01, 2018 | Microwave Ovens
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
95 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
