Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Get into motor
How can I disassemble this?
How can I buy a motor for my cleaner Model No 085830T MFG CODE DO7A.What will be the price for it.Thank you Dionisios Pletsas
Posted on Aug 30, 2008
Vacuum runs for a while then shuts off and then after being off for a while it works for again for a short period of time.
Sounds like motor overheating, disassemble and clean electric motor.
press the helpful button
Jan 03, 2016 | Vacuums
Bought used but was extremely dirty and clogged. I disassembled it and throughly cleaned it, replacing the power head belt and hepa filter and tried as best I could, to clean fillter over the motor
sounds like overheating. Is the hose clear? Check if there is air being blown out somewhere from the motor, if not, the motor can't breathe.
Mar 22, 2015 | Filter Vacuums
I have a InStyler (the rotating iron) by Tre Milano. This device is for styling hair. This is not a flat iron, but a cylinder that warms up and rotate's against a brush. It has 3 heat settings which...
I'm repairing an Instyler right now.
Troubleshooting, I connected a multimeter and measure the voltage where the motor is connected. When I push the button that makes spin it, I measure 12Vdc which is a correct value for that motor. Then I connected the motor and it did not spin. Therefore I need to buy one motor here:
http://www.makepolo.com/products/Linear-Motor-with-4.5-to-24V-p39074920.html
Same motor... yes you can repair it by installing a new motor.
Feb 04, 2013 | Vacuums
Power light on but motor won't run. where do i
the motor carbon brushes need replacing which is a most difficult job to get the cleaner disassembled. Brushes are easy to fit if You have replaced carbon brushes in other appliances etc..
Getting to the brushes in the Kirby is very difficult...
Lee in Australia
Jul 28, 2011 | Kirby Generation 3 Bagged Upright Vacuum
I vacumned up water
your vacuum will have to be completely disassembled. there is probably a clog that created in the cyclone due to the water mixing with the dirt in there. the cyclone assy will have to be disassembled and cleaned. unfortunately disassembling the cyclone voids dysons warranty i think.
Apr 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
It sucks from the hose, but not from the base.
I guarantee that there ia a wad of paper in the intake throat. This will necessitate disassembly of the bottom plate and removal of the beater/brush bar.) I am assuming an upright rug/floor vac, as I didn't get any model numbers/types from your description. This disassembly is very easy to do. Remove said items and dig deep into the intake throat at the motor. Good luck.
Feb 26, 2010 | Eureka 2903A Maxima Bagged Upright Vacuum
Disassemble electrolux olympia one vacuum.
Four nuts in rear housing, deep inside. Motor slides out after they are removed.
Jan 17, 2010 | Electrolux Vacuums
Bissell proheat 2x
After disassembling the unit to gain access to the hoses, the electric valve and the pump, I was able to determine that the pump was not working. NOTE: If you plan to test if the pump motor is working or not you must first remove the belt that drives the brushes from its motor pulley. This is done by first removing the C-ring that holds the pulley on the motor shaft, then slide the pulley, belt with it, off the shaft.This will allow the motor to turn without spinning the brushes. With the unit plugged in and turned on, pull the cleaning solution/water trigger. The pump motor has a short shaft sticking out and it should spin. You can touch the shaft with a finger and feel if it is spinning or not. I have no idea if the motor can be purched separately or if it is available only with a pump assembly. I also have no idea if you can buy either. I reparied the motor, but I will not go into detail on this at this time. Sufice it to say that the shaft was in dire need of lubrication. Most people would not elect to disassemble the unit to the extent that I did and I would simply recommend taking it to an authroized service center.
Sep 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replace power cord
http://www.rainvac.com/schE1.pdf
Jul 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
Hoover u8173-900 think motor is bad but how to disassemble
Is this a Savvy? If so your problem may be in the handle switch asm or one of the circuit boards. The switch is really a problem, but they have come out a hopefully a better one. If it is the motor, take it aprt, you can check it with an ohm-meter to see if you have reading or if it shows an open. If it isn't froze up, and has an electrical burn smell, then the field of the motor is bad.
Apr 27, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
104 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
