Question about Ics Hop Up Bucking for Airsoft Guns
My Crossman Pulse R71 has a slightly larger BB jammed in the Barrel is there any way I can fix this?
4 Suggested Answers
  • 8 Answers
SOURCE: MY crosman pulse r71 airsoft gun won't shoot
get a dejamming rod and put it through the barrel because its most likely jammed
Posted on Jul 23, 2010
SOURCE: I have a Crossman 357
i put a little piece of wire under the clip,which holds it up.
Posted on Dec 30, 2010
  • 3 Answers
Have u tried unscrewing the gun and see wht is wrong
Posted on Dec 28, 2012
My daisy powerline 201 is jammed. There is a pellet in the bb hole and I cant get it out?
buy/get a brazing welding rod,they come in 3\' or 4\' lengths ,insert/slide it down barrel ,make sure magazine is removed first and cock is pulled back retract rod slightly until pellet wiggles free or retry... this used to happen to me all the time...
Aug 10, 2014 | Toys
I have a crossman 1377 (177) cal pellet pistol. Is it ok to shoot BB'S in this gun? Does it damage the rifling in the barrel? Thanks, Gary
yes it safe to shoot bb,s in the 1377 pump pistol,i have 3 of them they actually shoot true'er and with more vilocity
Sep 19, 2011 | Crosman 1377 177 Single Shot Air Pistol
I have an older Crossman BB gun marked "Crossman
Time to buy a new model. I had 2 of those with similar problems and couldn't find parts. Try the CO2 model 1088. I'm happy with mine. Spray the seals with silicone spray monthly or every 2 cartridges.
Sep 10, 2011 | Air Tools & Compressors
I have a Crosman Pulse R71 Model SAPR71. Its a Soft air gun using plastic BB's. When I shoot the gun, it has no power. The battery is fully charged but it seems like there is not enough power to shoot...
I had the exact same problem.. turned out to be that the cylinder wasn't lubricated properly so it wasn't sliding well.. I dripped some lubricant down the barrel and it shot like a champ! (ps, I used the wrong lube and I'm too lazy to look up the correct lube, but either way, that's your problem)
Apr 24, 2011 | Toys
My crosman stinger s34p shotgun shells keep jamming help
Mine did as well. Worked fine with the 500 that cam with it, but when I tried other brands had no luck. I did finaly bot some crossman BB's .12g the 13,000 bucket. They jammed as well but they came with 2000 .12g glow in the dark BB's and they work fine. Not sure what the answer is but I am going to get some diffrent shells and try them. Its odd not may post on this.
Apr 03, 2011 | Sport & Outdoor - Others
MY crosman pulse r71 airsoft gun won't shoot it just makes a humming sound
May 23, 2010 | Ics Hop Up Bucking for Airsoft Guns
I work the lever to load one BB. then pump 6 or 7 times. BB will not shoot out. When I pull the trigger, it sounds like it is shooting, but no BB comes out. this is for a crosman 760 pumpmaster. it...
Can you see through the barrel? Or run a rod down the bore? It sounds like the BB is either falling out the end of the barrel or the BBs are getting jammed up in there. Do not hold your hand in front of the barrel to see if any air comes out. You might get stung with 10 BBs. Hope this helps.
May 22, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Apr 05, 2009 | Toys
Co2 leaks from chamber on crossman modle400 rifle how do i fix it
Check thare is a rubber o ring missing or broken in the air chamber
Mar 29, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Ics Hop Up Bucking for  Airsoft Guns Logo
73 people viewed this question
Top Ics Sport & Outdoor - Others Experts
Bill Eager
Are you an Ics Sport and Outdoor - Other Expert? Answer questions, earn points and help others
