Question about Maytag Dryers
Maytag dryer MDG3000AWW does not heat - Maytag Dryers
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
Mdg3000aww gas dryer. drum turns. ignitor glows and goes off but no flame.
I suppose you made sure the gas is on. The valve probably has two valve coils sitting on top; one is a dual coil. My guess is that one coil is "open" (no continuity).
Sep 07, 2011 | Maytag Neptune MDE5500AY Electric Dryer
On MDG3000aww the dryer is not heating, How can I get it to heat? Do I need to call the gas provider or a service expert? If this will cost over $300 I want to just replace the appliance.
Below is a video to show you how to diagnose your dryer "no heat" problem. You will need a multimeter to troubleshoot with. Here is a list of the parts you may need depending on the ones you find that are bad. Don't worry, this is just a list of the parts that go out and does not mean you need to replace all of them. You will find that only one or two are bad. Please let me know if you need any further assistance.
Dryer Igniter Three Terminal Gas Coils Two Terminal Gas Coils Flame Sensor High Limit Thermostat Thermostat Thermal Fuse
Jan 03, 2011 | Maytag MDG3600BW Gas Dryer
Model no. mdg3000aww Sometimes the gas will turn on to heat but will stop before the cloths are dry. Then there are times when the gas will not go on.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Maytag Dryers
May Tag Gas Dryer Model MDG3000AWW - Dry works but no heat, more dry/ less dry lights flashing. Whats wrong? How do I get heat again?
it is either your glow coil or it is your ignitor
open the door and remove the four screws
take the front panel off.
leave the door attached so you can test the dryer
be very careful not to touch any wires while you are doing this
now close the door and turn the dryer on
does the ignitor turn on?
if yes that is good
does the ignitor glow and no flame?
sometimes it will take a minute to show it's problem
if the ignitor glows and no flame replace your ignitor coils
make sure to turn the power off when replaceing the coils
Aug 24, 2010 | Maytag Dryers
MDG3000AWW Maytag Neptune Dryer. Not heating correctly
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 02, 2010 | Dryers
Maytag neptune model mdg3000aww heats for 20 - 30 second then the burner stops.
The most common failure item is the gas valve coil(s)
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below are some links provided by, www.repairclinic.com. This can assist you with diagnosis, parts ordering and replacement.
Dryer parts breakdown link:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Coil illustration link:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg3000aww-%3d%3di686303&PartID=686303
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 15, 2009 | Maytag Dryers
Maytag MDG3000AWW Hard starting
your motor bearings or idler tensioner bearings are going dry and need repl
Aug 03, 2009 | Dryers
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mdg3000aww some times no heat
good that will solve the problem THE APPLIANCE DOC
Sep 12, 2008 | Dryers
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
Dryers Logo
292 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
