I want to upgrade my video card. i see some take 500 watts and others take much. so. it seems i need to know the wattage of the power supply.
    Novelist:
  • 137 Answers
  1. Turn off Your Desktop
  2. Discharge it by pressing the power button after you took the plug out (you may see the power lamp turn on for a second or two)
  3. Open the side cover of your Desktop
  4. Look at the IN-side of where the Power cord Goes into your Computer
  5. You'll see a fairly large box (right behind where the wire went in)
  6. The Box has a harness of many colored wire coming from it
  7. There you will find a label listing all of the information such as Make Model, Voltage, Wattage, etc...
If you are wanting to buy a gaming card, or Video (such as for Media Center use) , it is recommended that you DO buy a larger Power Supply. Otherwise, you CAN buy Video Cards that require less wattage.
Thank You For Choosing FixYa~!
Posted on Mar 19, 2011
Testimonial: "Great tutoral. i am now looking for a video card with a lower power requirement. i am not a gamer: just routene stuff. Thanks."
  • 604 Answers
Your power supply rating is either on the back of the supply, or in the paper work that came with you computer. You should not need more than a 500 watt supply to run everything on your comp
Testimonial: "the power supply was not in any of the paper work from HP or the outside ot the computer, and i do not want to open it until i i have a plan. But, yo"
  • allan mcpeak Mar 19, 2011
    But, you stimulated me to re-examine all ot the papers including the pc mag evaluation where i found the info in their review ie, 300 watts. No, thanks to the HP people.
  • Keith Brown
    Keith Brown Mar 19, 2011
    300 watts is not enough power, especailly if you add periferals (cards) to your computer, power supplies are easy to change, and they don't cost much. you can buy a 500 or 600 watt for 50 bucks, maybe a little more.. I have stopped buying anytning from HP, cause they are getting really cheap with their equpment.
I want to upgrade the power supply on a gateway lx 6200 but i don't know what i can replace it with model no is fsp 400-60thn 400 watt and i would like at lease a 500 watt
unlike dell other desktop computers take a standard power supply as long as its not a mini sized one.
if you power supply is this size
then you just wanna buy one that has all the connectors you need for all of you internal devices
then find one that has the wattage you want
Apr 25, 2011 | Gateway LX6200-01 PC Desktop
Need to upgrade Alienware PC with P5GD1-VM
You need 24 connection power supply 500 watt
Apr 29, 2010 | ASUS P5GD1-VM Motherboard
How to check if my power supply is already not ''at the limit''?
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
Mar 22, 2010 | Cooler Master (RS-430-PMSR/P) (RS430PMSRP)...
I want to upgrade video card for my pc(HP Pavillion a1120n) i wanted to know what kind of video card is compitible with my pc. please help thanks. ;)
From what I gather, your computer has a PCIe v1.0 slot for a video card upgrade and comes with intel on-board video. So you will need a PCIe 2.0 video card (v1.0 are no longer available and 2.0 are backwards compatible)
I assume, like most PC's, yours has a 350-450 Watt Power Supply. Check your power supply to be sure, you just can't put any video card, you are limited to the available power from the power supply. If you want a top of the line video card for gaming you will need a more powerful power supply. If all you need is better performance and better video quality (DVI/HDMI) then any sub $100 dollars card will do.
I cannot emphasize enough, check your power supply wattage capacity and the watts required by the new card before buying.
Also, do you have additional power connection from the power supply for the new card? most cards, not all, require a 6-pin PCIe power connector.
For the average user I recommend:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
Mar 13, 2010 | HP Pavilion a1120n (PX759AA) PC Desktop
Computer reboots when running games like hoyle ,just set up web cam,for telecall, computer rebooted after a couple of minutes seems like anything with a video type task.Possibly need new video card?
your card is pulling too much power. check the wattage rating of the card and the wattage output of your power supply . good rule of thumb  you want about 20% more that your card rating  450 watt card needs 650 watt power supply to run well. the extra is for your other stuff (dvd burner ,ect)
Feb 13, 2010 | ATI RADEON Graphic Card
Need to upgrade HP3087F3 to a more powerful power
depends on what your going to do....bigger video card? I would max it out
Jun 23, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
Upgrading power supply
The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
Get an OEM PSU from Compaq(HP).
Dec 02, 2007 | Compaq (253219-002) Motherboard
Upgrade Video Card
I would recommend picking up a higher watt power supply just to keep up with the changing demands on computers. They are not to do yourself. If still wondering what cards can go with a 300 watt power: Maybe an ATi Radeon 9250 256mb? It seems that a 350 watt power supply should still be minimum nowadays and they are cheap.
Oct 30, 2007 | HP Pavilion m7480n (882780389410) PC...
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
