Question about Euro-Pro 9130 Sewing Machine
Took the plate off because the bobbin holder seems to be jumping up and down not sure if their should be a screw holding the centre or if it broke or came lose and is in bottom of machine. Or the bobbin holder screws in and attached somehow tried numerous times. Bobbin hold sits in but jumps around now when sewing it should latch in or have a screw. Euro Pro 9130 XC
SOURCE: thread keeps snapping on NEW Euro Pro 32-Stitch sewing machine
I also have the same sewing machine. The machine is not very user friendly and the instruction manual doesn't really illustrate the right way to thread the machine. For the bobbin, make sure you thread it through the two tiny holes in the small rectangular metal piece in the bobbin case. I had to use a dental floss threader and tweezers to thread the bobbin correctly, if you can believe it! As for the upper thread, follow the directions EXACTLY as illustrated in the manual. Don't miss the little loop underneath the machine or the tension will be wrong.
Also, use extra strong thread. I used a professional quality break-resistant thread from Germany for both the bobbin and top thread, and the machine works okay.
Posted on May 19, 2008
RickE1
  • 202 Answers
SOURCE: how to load bobbin into
When you have the bobbin wound and placed in the bobbin case pull on the thread. If the bobbin turns counter-clockwise the bobbin is in upside down. The bobbin must turn clockwise when you pull the thread looking at it from the back..
Then slip the thread into the notch and pull it up under the flat spring up into (through) the hole.
Thats it, now snap it in the machine.
Posted on Jul 24, 2008
  • 749 Answers
SOURCE: won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Posted on Nov 01, 2008
SewTechWayne
  • 186 Answers
SOURCE: Bobbin winder won't spin
The two most common problems are that you either need a new bobbin tire, or just need to adjust the position of the winder a little closer to the hand wheel. Remove the top cover and you will see the winder assembly. Loosen the two screws that hold the assembly nudge it closer to the hand wheel side. If you move it too far the winder will constantly spin. Also, examine the rubber tire, it may have a flat spot on it in which case it needs to be replaced. If it is worn out you may not be able to tell just by looking at it.
These winders can be tricky to adjust but why not try?
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: I have a Husqvarna Emma sewing machine. The
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
Posted on Apr 19, 2009
Singer4562T.Took bobbin case apart.Metal plate on rt. had 3 screws,there was a tiny spring? Now metal plate is lose & bobbin case jumps out of holder.Is that plate supposed to be tight?
Do you mean you took apart the round case that the bobbin fits into, or that you removed the bobbin case from the machine body?
Either way, if there was a spring, it will have provided tension for some reason and if you don't have the spring now you won't be able to get the thing to work properly.
If you can show images of the case, the parts you have and where they fitted into the machine, maybe I can help a bit more. Is this a vertical vertical bobbin case or a horizontal one ? I have an older Singer myself, not this specific one, and it has the horizontal, drop in bobbin
Nov 27, 2017 | Sewing Machines
I can't seem to get the bobbin holder in there correctly to get the machine to sew properly.
While I know it can only go in 1 of two ways, maybe the problem isn't in how the bobbin is in, maybe it is the route of the thread.
My assumption is you don't seem to pick up the bobbin thread and it bunches. If so the carefully follow the thread to needle you may have by passed the place you put that thread so it maintains tension.
Check that carefully, sometimes that gets overlooked.
Jan 16, 2015 | Sewing Machines
Need a blow up diagram of the timing parts for Shark Intelli-Sew Euro-Pro Model 9110.
I had a timing problem, I believe, and fixed it. But its not yet perfect.....What happened was the top thread was not being caught by the bobbin holder. So when I "sewed", there were no stitches. When I watched the bobbin through the window, the bobbin didnt turn, and thread didnt whiz around the bobbin holder as it should with each stitch. I even made a video to see if there was a timing problem...the needle went down well before the bobbin holder "thread catcher hook" arrived to catch the loop. So I took off the plate underneath the bobbin holder, and adjusted the timing. When you do that you will see a cogwheel that rotates as the bobbin holder rotates. Three alan wrench screws hold it tight to the axle that rotates with the handwheel/footplate. I loosened the alan wrench screws, and then did the following. Hold the needle holder so it doesnt move, and at the same time turn the hand wheel a little. This adjusts the timing of the needle relative to the bobbin turning. then plug the machine in, and see if the bobbin wheel is now catching the thread. Keep adjusting until it does. Then tighten things back up, and VOILA! Im not sure this is the best way to adjust the timing, but it works. My machine went from no stitches at all, to sewing nicely. Its not yet perfect, as it jams every now and then. But that may be because the timing is still a little off, or because the thread is bad, or the tension of the thread is not quite right......working on that still.......
Sep 11, 2012 | Sewing Machines
I broke a needle on something hard. After I replaced the needle it wouldn't go all the way down. I took the screws out and removed the piece that holds the bobbin. I can't seem to get it back in so that...
This sounds like your metal plate needs adjustment. Loosen the screws and adjust it until the needle goes all the way down. If that doesnt work, ensure that your bobbin case has been aligned properly.
Apr 07, 2010 | Brother CS6000i Computerized Sewing...
Problem w/ metal plate over bobbin
try and find the screw dude... either that or try taping it down i know it's not an ideal solution but it's a quick fix until you can replace the screw
Mar 07, 2010 | Sewing Machines
METAL PLATE COVERING BOBBIN WON'T STAY DOWN
Take it apart again and compare the original screw with the one you substituted. If they are not the same size, you will need to get one that matches the original.
Re-place the needle plate and when firmly in place, put the screws back in.
Mar 03, 2010 | Sewing Machines
SINGER CG 550
If the plate is moving up and down eithetr the teth are set far too high pushing the plate up or the teeth are set too far forward, I would go for the first, if the teeth are coming up well above the slot they are too high, they should be set so that when you look alongside the plate you can just see the top of the teeth, you can adjust the teeth by adjusting the screws underneath the machine where the teeth are.
Mar 03, 2010 | SINGER 7470 Sewing Machine
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Jan 30, 2009 | Sewing Machines
I removed the positiong plate
I removed the posiotioning Plate(A). Singer Inspiration 4205. How can I get it back in?
Sep 23, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Euro-Pro 9130 Sewing Machine Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
