Question about Philips Audio Players & Recorders
My gogearvibe will not charge - Philips Audio Players & Recorders
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird or device manager. If your model number starts with SA1..... your player supports device manager. If it starts with SA2.... then it uses Philips Songbird. You can install them from the CD that came with your player or download it from Philips support site.
Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Posted on Mar 20, 2011
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
What is this vendosupport.com?? Why is money transacted to this site without my knowledge??
mony tarnsactions with out my knowledge in vendosupport.com i went to cansel the taransaction
May 04, 2011 | Computers & Internet
I plugged my Philips 4GB GoGearVibe mp3 player into my computer to charge but i am not sure if i plugged in all the way. This has happened before where the battery died but came back when my dad charged...
if you are charging via usb make sure you have the computer (if its a laptop) plugged in and if you are using a pc make sure your using one of the usb ports on the back as some usb ports will not carry the 5v needed to charge your player.
Mar 27, 2011 | Philips SA5125/37 MP3 Player
I can't use my itunes account to add or subtract my music, since adding the gogearVibe. had the same set up approx. 5 months ago with a different unit that worked fine. What happened?
You need to use the Philips songbird software to transfer itunes music into your MP3 player. If your player doesn't use Songbird, you need to first convert it into MP3 format under itunes then transfer using windows media player 11 or higher.
Here is how ot import files from itunes to Songbird:
  1. On the computer, launch the Songbird program. Select Tools > Options
  2. On the Songbird toolbar, select the Media Importer tab, then iTunes Import/Export.
  3. Verify your library location and options. Select Import Library.
  4. The software imports the iTunes library into Songbird.
Once this is done, your itunes music will show in Songbird library. You can now transfer it to your GoGear player. Here is how to transfer files from songbird to your MP3 player:
  1. Click "File" in the toolbar and select "Import Media". Choose the folder that stored your media files.
  2. Select the media files that you want to transfer and then Right Click to display a drop list (You can press and hold the Ctrl button on the keyboard to select more than one file).
  3. Select "Add to Device" and "(Your player model)".
Or you can to go to Songbird library and then drag and drop the files to your MP3 player's icon on the Songbird software.
Hope this helps..
Mar 05, 2011 | Philips GoGear ViBE Digital Media Player
I accidently reset my vibe and it wont play or show anything except the gogearvibe deal?
Ok, in this case you can format the player. Contents may be removed by using this function. So make sure to back up your contents. Here is how to format:
Connect your player to PC. On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
If that doesn't work, repair it with Songbird or Device manager. Whichever application your player uses.
For Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair my Philips GoGear" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
For Device manager:
Launch Device Manager and click the Tool menu and select "Repair my Philips GoGear", then follow the instructions to perform the repair process.
You player should work correctly now. Hope this helps.
Dec 15, 2010 | Philips GoGear ViBE Digital Media Player
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Is a phillips GoGearvibe compatable with itunes
There are 38 variant players for the GoGear Vibe, see next page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=GoGear+ViBe
Look up the exact model in the list, revealing in what country the model is being sold. Remember or write down the exact model number, you want to check the players' compatibility with iTunes for.
Select your country in the page top and enter the model number on the left side, e.g. United States + SA1VBE04B/17. Next model will show up:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1VBE04B/17&slg=ENG&scy=US
Put in the bar "Search for information about this product" the word iTunes, go for a search and next Frequently Asked Question is listed:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?slg=AEN&scy=&ctn=SA1VBE04B/17&refnr=0075168&dct=QAC&session=20091120183537_94.214.10.98&searchtext=itunes
The link tells how to transfer iTunes music for this model player, the SA1VBE04B/17 .
Nov 20, 2009 | Philips GOGEAR SA6045 MP3 Player
How to unfreeze philips gogear 8gb mp3
Connect the player to power and pc. Reset the player by holding the off-switch and the volume-+ (plus) switch., and as soon as the player shuts off, press and hold the volume- - (minus) switch. The philips device manager should come up now and recommend a repair, let it do so.
Jul 08, 2009 | Philips GoGear HDD6330 MP3 Player
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
