Question about Garden
Toro Z4200. 60 hours. The starter has always seemed balky but never failed to start. Now, with a completely charged battery, it would not turn over although it sluggishly tried. Seemed as if the starter was not getting enough voltage. Now the problem is it blowing the fuse. I disconnected the starter from the solenoid and it still immediately blows the fuse when the ignition switch is turned to start. It is still under warranty but if it's something easily identified (like needs new solenoid or ignition switch) I'd rather just replace the item instead of loading it up to drive it 50 miles where it will sit for God knows how long. Thanks!
    Top Expert:
  • Garden Master
  • 48,313 Answers
If you touch it , the warranty is void
best talk to the service dealer and get written permission before you touch it
blowing fuses is a dead short after the fuse
could be a problem solenoid ( dead short inside )
Posted on Apr 08, 2017
4 Suggested Answers
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
  • 109 Answers
SOURCE: fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Posted on Jun 29, 2009
  • 1033 Answers
SOURCE: Poulan Pro riding lawnmower 42
Replace the battery. Even though the battery may say it's good, it doesn't have enough of cranking amps. Go purchase a battery with 350 cranking amps. This will fix your problem. The battery power isn't enough to kick the starter completely up to turn the engine.
Posted on Jul 06, 2010
My Toro LX425 riding mower will not start has been fine all season; battery indicator light on but wont turn over; starter?
First make sure your battery is fully charged. The charger on lawn tractors will not keep the battery fully charged as they just produce a light charge. Check battery before the starter but if battery is fully charged then it's possible the starter could be bad.
Oct 15, 2016 | Toro Garden
I have a Toro 16.5 riding lawnmower it stop and wouldn,t start back what could be my problem?
Battery charged? Bad fuel? Low on oil? 30w oil required. Clean carb. Check for improper ground on starting circuit. Ignition switch providing power to starter when key turned? Always use Stabile in gas. Remove bowl from carb ensure float is working properly. Float up no fuel flow, float down fuel flow. Ensure oil is full, low oil shutoff will not allow starting.
May 30, 2013 | Toro Lawnmower Lawn Mower SP Drive Belt...
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
May 15, 2011 | Toro Titan ZX5450 (54") 25HP Zero Turning...
I have purchased a Toro zero turn mower and can't get it to start. It has gas, I charged the battery. It makes a clicking noise when I turn the key but motor won't turn over. Is there any special way to...
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Jul 27, 2010 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
New battery won't take charge
Hello, and how are you. It could possibly be the charger itself If everything else seems fine. If all wire connections at the starter and the battery are tight, clean and no cuts any where on the wires them selves.I would try a new charger. Another thing is you could see if someone could check the wires with a meter to see if there are any unnoticeable breaks in the wires.
Jan 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
