Question about Apple iPhone Smartphone
When I try to take a picture, it does not make the clicking sound and goes right back to the main screen. My iphone 3g is only 3 weeks old and worked fine until today. Thank you for any help.
    Master:
  • 344 Answers
Try a forced shutdown. Press and hold both the sleep (top) button and the home key for about 10 seconds. This will force it to power-down completely. Press the sleep button again for about a second to start it back up again. Also, look into any and all apps you have downloaded. You might have one that is being a memory hog. If all that fails, contact Apple about any warranty on the phone.
Posted on Mar 19, 2011
WHEN I TRY TO SEE RECENT CALL HISTORY THE I PHONE 3 GS REVERTS TO THE HOME SCREEN. IS THERE ANY WAY OF RESOLVING THIS?
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Jun 30, 2011 | Apple iPhone 3G
My iphone 3g screen is not responding. i can receive calls. messages. unlock/lock button works fine and also the home button works fine. please help!
This sounds like a problem with possibly 3 things. One you may not have the lcd ribbon cable fully in place. You may have purchase a faulty LCD. The main board in the phone has a short and its not getting the full connection to the screen causing only the backlight to function
Oct 09, 2010 | Apple iPhone 3G
I just started having my screen of my Iphone (3G)
hit the screen with 3 fingers i know it sounds weird but should work
Mar 16, 2010 | Apple iPhone 3G
I forgot the password for my iphone
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
  1. Click the Home button to bring up the main menu
  2. Click on Settings
  3. In the Settings screen click on General
  4. In the General screen click on Passcode Lock
  5. This will open the Set Passcode screen. Enter a memorable 4-figure code and re-enter it when prompted
  6. You will now be at the Passcode Lock screen. You can change when you are prompted to enter the Passcode. The default setting – Immediately – means you will be asked to enter it as soon as your start using the iPhone. But you can change the setting so that the prompt appears after a certain period of use
  7. Press the Home button to return to the main menu.
Dec 11, 2009 | Apple iPhone 3G
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 29, 2009 | Apple iPhone 3G
Iphone 3g is frozen and touch screen wont work
If this unit is jailbroken you may want to do a full restore of the device, you will need to get the Iphone turned on and connect it to itunes, when you get into I tune and you phone is seen, right click on the device in itunes and tell it to restore.
This will reset the phone back to defaults, you will loose most of your data if not all.
If you can't get it to stay on or come on in Itunes then you may need to try this.
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Aug 30, 2009 | Apple iPhone 3G
Jailbroken iphone 3g frozen screen
samevthing happened to me your gonna have to plugg your iphone into the comupter and hold the power and home button down at the same time until it shuts off. Keep holding the buttons down until it powers back on. there should be a picture of a guy wearing holding his hands up in the air on your iphone and itunes should open up on your computer. Now you will have to restore your phone.
Jul 08, 2009 | Apple iPhone 3G
My Iphone's screen won't turn on but still vibrates
I had the same problem just now with my iPhone 3G. It froze for like an hour and a half! I heard calls come in but wasn't able to answer because the screen wouldnt come up. I pressed the top clicker button and the main button for about 10 seconds and the apple logo came up (finallyyy). It took about another minute and then the screen came back up and prompted me for my passcode. I hope this can help you all!
Jan 02, 2009 | Apple iPhone 3G
2.2 Jailbroken iPhone 3G dailer crashes! Help!
If after the jailbreak you can't make dial calls because the phone dialer freezes and goes back to the main menu, try this:
1- Uninstall Kate from Installer: this is what everyone recommends, seems to work for a lot of people but didn't work for me.
2- Then go to Installer again and uninstall these apps:
A) Mobile enhancer
B) RIP DEV preferences
3- Reboot your iPhone.
That's what I did and got my dial pad back again.
Dec 27, 2008 | Apple iPhone 3G
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Apple iPhone Smartphone Logo
26 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
