Question about RCA P52937 52" Rear Projection Television
I have 52" PS2937SG the
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Posted on Dec 07, 2007
SOURCE: picture doesn't fit screen
my rca truflat tv projects a larger picture than the screen, its really annoying i play my 360 and it cuts off alot of the screen so i cant read messages on the left and right of the tv screen, there are no options to adjust the ratio so all there really is to do is to buy a new t.v. if you are reading this i recomend you do not waste your money on a TruFlat RCA T.V. If somebody has a solution please let me know it would save me money and would make me very pleased.
Posted on May 14, 2008
  • 2920 Answers
SOURCE: RCA Projection screen tv, model #D61W20B
your cameras may have gone bad
Posted on Sep 03, 2008
ladywinn
  • 5138 Answers
SOURCE: rca 52'' projection tv model p52937
Go to menu ,now to setup when in set up do you see convergence? If convergence is missing in menu it is a open fuse,only it does not look like fuse ,They look more like small square capaitors brown, they will be right next to flyback transfomer FL231 (3) of them in a roll it will be the middle one,you can take needle nose plyers and pull top up on fuses.
Posted on Dec 18, 2008
SOURCE: RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Posted on Sep 23, 2009
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
Fuzzy screen
Next time take it to a video input (ones on the rear) and see if working there or not.
Jun 16, 2012 | Mitsubishi WD-52825 52" Rear Projection...
RCA 52 inch fuzzy screen no buttons work no sound cable doesnt work on it just fuzz
First is you removed power by unplugging the surge protector---this may have confused the micro in the set.
Unplug the set itself (with it turned off) for a while and plug it back to see--sounds like this is your problem to me. Usually in this case only the on/off button on the set works.
Mar 27, 2012 | RCA HD52W56 52" Rear Projection HDTV
MY MONITOR SCREEN IS FUZZY. UNSURE THE CAUSE OF THIS, PLEASE HELP; COMPAQ MV730I MONITOR MAY BE JUST OLD ALREADY AND I NEED TO REPLACE IT.
Difficult to say as there are several possibilities. First would be to narrow them down. You may have already tried this, but wipe all dust off of the screen to see if that helps.(Do Not spray liquids on you monitor, if a cleaning agent is necessary, use a damp wipe to remove debris. If a single drop gets past the monitor's bezel in the wrong place, it will cook the monitor or worse, cook you.) If that didn't work, then, if possible, run the monitor on another computer. If that clears things up, I would suspect either a driver or hardware issue with the computer. If the screen is still fuzzy on another computer, then it is definitely the monitor. As CRT's age, many things happen. One is that the phosphor wears out from being shot at by the electron gun and start to go dim and then fuzzy as the intensity is increased by the user to make things brighter. Another thing that ages is the high voltage transformer. As the transformer weakens, it is no longer able to shoot a sharp beam of energy and begins to splatter a bit of energy on the surrounding pixels which would make the screen appear fuzzy. If the CRT has controls for adjusting intensity, contrast, saturation (those are sometimes hidden behind a small panel) tweak them one at a time remembering where the original setting was to see if that clears things any. ***DISCLAIMER*** (Note: Some monitors have the controls inside. If you are not experienced with adjusting high voltage devices DO NOT DO IT!!! A monitor is not worth your life, and if you disrespect high voltage even by accident, the potential is there to kill you!) Above all things, BE SAFE, and then choose what is best for you to do. Best of luck.
Sep 19, 2011 | Compaq MV 730i (White) 17 in.CRT...
I have a blue screen that says "not support!" i have checked all connections to my television and my direct tv box will not show the screen
It is due to the video resolution feeding the TV is too high for the TV to display, same thing applied to PC monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please ask direct TV on how to adjust the Direct TV box video resolution output.
How is the TV attached to the Direct TV box, HDMI, COMPONENT CABLE, ETC?
Aug 26, 2011 | Dynex DX-LCD37 TV
My sony tv is fine after switching after few minutes the screen gets fuzzy, why?
Are you using your TVs built-in tuner or a separate cable/satellite box? Does this happen on other input sources?
May 05, 2011 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
I bought an intec gamecube color screen and everything works accept that the sound output is EXTREMELY fuzzy. I plugged in all the wires I could that came with the screen, but there is an empty outlet that...
AV-in is for using the screen for an alternate input, such as a different console. If the sound is fuzzy, you may have a dirty connector or port. It's also possible the speaker(s) are bad. I've seen bad soldering connections or damaged wiring cause this on the inside also.
Sep 08, 2017 | Intec GameCube Monitor
Dull colors, dim images
Where did you buy the lamp at? Does it look the same or worse than when the old lamp was in there and working? Is there a big difference or if there wasnt another tv sitting next to it mabe you wouldnt notice? Also you dont need to clean the screen, that could damage it. If you are going to clean anything you will need to clean the mirror behind the screen.
Sep 16, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
RCA Big Screen is fuzzy.
Common problem and RCA recommends the following to cure: replace R17520 with p/n# 218508, C11503 with p/n# 194903, and crystal.
Bill
Dec 12, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
