Sensitive cursor - I have adjusted touch pad settings - cursor jumps and and will not allow you to select things easily on the screen.
    Sergeant:
    Champion:
  • 285 Answers
Have you checked your charger because some times not having the right charger can do that to the mouse
Posted on Mar 19, 2011
How do you stop the cursor from jumping on an elitebook folio 9470m
go to control panel / mouse to open the mouse properties window. along the top of the window should be several tabs. select the tab for touchpad or maybe advanced properties. this tab allows you to adjust the touch sensitivity of the mousepad, momentum, and other properties. adjusting to make it less sensitive may reduce the tendency of the cursor to jump or move on its own. failing that, go for an external mouse!
Aug 14, 2014 | HP EliteBook Folio 9470m 14in LED...
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
I am using T400 with XP Pro. while typing Touch pad is so sensitive that it jumps the cursor from writing one line to other. End up that you need to type all the items again and again. is there any way...
Try this first
To do this, open Mouse Properties within the Control Panel, where on the Ultra Nav-Tab you find a button for touchpad settings. Click on this button and another window will open which has a tab for adjusting the sensitivity of the touchpad. Moving the slider to the left (towards "higher" ) greatly improved my experience with the touchpad.
For me, setting it to the second highest "line" (i.e. second line from the left) works best, but you may be able to set it even higher as I have not yet encountered any negative effects when doing so.
I would be glad if some of you could try to verify my findings, I am very much looking forward to your experiences.
Step 2
Click on the link below and follow the instructions
Also try this step below if above steps does not solve
  • Right-click on 'My Computer' and then select 'Properties' in the context menu. This opens 'System Properties' dialog box.
  • Click on the 'Hardware' tab and then on the 'Device Manager'. Here you will ?nd an entry titled 'Mice and other pointing devices' in the 'Device Manager' window. When you double-click on this entry, it shows the touchpad as a PS/2 Compatible mouse.
  • Right-click on this entry to go to the properties of the touchpad, select 'Advanced Settings', and then click on 'Sample Rate'. You can reduce the degree of sensitivity here.
  • Follow this tip and you can solve the 'jumping cursor' problem easily.
Thank you for contacting FixYa
Nov 27, 2010 | IBM Lenovo ThinkPad T400 7417 Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
When I am typing he cursor jumps around
It is a fault with Lenovo laptops. My cursor jumps all the time, no matter what software I am using. It is NOT the 'sensitivity' of the touchpad, for my cursor jumps even when I am not typing, even if I don't touch the laptop! I can set the cursor to a certain point on a document and then, after about 30 seconds, it will just jump to another point, even if I am in another room.
Sep 24, 2009 | Lenovo 3000 Y410 Laptop
Cursor jumps around screen when typing
your dell laptop are supposed to have a program on touchpad, if you dont have that in your system then the touchpad is jumping
Jun 17, 2009 | Dell Latitude D630 Notebook
Over sensitive touch pad, causes cursor to jump all over the LCD
Try control panel and double click the mouse icon then settings you can adjust sensitivity there
Dec 28, 2008 | Sony VAIO FRV25 Notebook
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Moving cursor.
well there is a few things that could possibly be happening. if it is a touch pad or a wireless mouse something like a cell phone sitting close enough to them could be causing some interference. the second one is that you could possibly have the mouse keys turned on where you can control the mouse with the keyboard.
Apr 29, 2008 | Dell Latitude D800 Notebook
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
