Question about Air Tools & Compressors
I need head valve seal for a central pneumatic air roofing nailer model 41209
SOURCE: Need Parts for Central Pneumatic Air Framing Nailer D1CN28/90
I have a Central Pneumatic Frame Nailer the driver will go down but not back up unless you disconnet air supply.
Posted on Sep 14, 2009
brewerstool
  • 141 Answers
SOURCE: I have a Central Pneumatic air nailer that has the
You can call Harbor Freight and see if they have the repair kit available. 1-800-444-3353. Sometimes they change the models and will not have parts available. It may take up to 6 weeks for you to get your parts if they are available. Be prepared to wait. The parts will not be expensive. Depending on which seal you are talking about, you may have to order an assembly. I am directly talking about the trigger seal. This part seems to crumble the most. If you require more information please post additional information about your model and the seals you are requiring.
Posted on Oct 12, 2009
wiringlunati
  • 576 Answers
SOURCE: central pneumatic air nailer leaks air around
Probably needs the trigger valve rebuilt/replaced. Contact Harbor Freight for replacement parts.
Posted on Nov 25, 2009
  • 6 Answers
SOURCE: I have a central pneumatic palm nailer leaks air
sounds like a bad o ring inside the housing .
Posted on Feb 01, 2010
  • 1388 Answers
SOURCE: central pneumatic air framing nailer
The phone number for parts is listed below, however it has been my experience that Harbor Freight does not stock many parts. If you can't find parts at HF, find a local professional fastener store that deals in air nailers and ask them to match-up a seal (get close). These seals are common to nailers and most framers have a similar size cylinder. If you like to tinker ~ I have found seals that are a bit larger but you can fill the gap with RTV. If a bit small, heat gun will make it stretch a bit. I am a heavy duty tinker-er with a small lathe. I have made these seals by taking a roller blade wheel (from thrift store, used set of roller blades cost about $5 nets 10 wheels) and turn out a high quality seal. The first seal that I constructed was made using a piece of dental Mouthguard material. Mouthguard material comes in different thickness. I used 1/8" thick material. I cut out a circular piece of material that extended past the diameter of the cylinder about 1/2" (if cylinder is 2 inch dia. then disc is about 3 inch dia.) Mouthguard material (or similar) can be shaped by using a heat gun. Remove cylinder and place in vice or stable place. Place disc of material centered on top of cyl and apply hot air until it softens and shape material down to form seal (use headvalve to shape top of seal by pressing valve on top of seal while still hot, spray silicone on any tools to prevent them from sticking to the hot material). Allow material to cool then cut out center with hot exacto knife. Your new seal can be removed then re-installed on the cylinder using RTV sealant. Good luck
1-800-444-3353
Posted on Mar 31, 2011
LOOKING FOR SEAL REPALCEMENT AT TOP OF PISTON
Search Results
    [PDF]How to Repair you Nailer - Master Tool Repair
    www.mastertoolrepair.com/.../How%20to%20Repair%20you%20Nailer....
    Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
    Rebuild a Framing Nailer ' The Family Handyman
    www.familyhandyman.com/tools/air-tools/rebuild-a...nailer/view-all
    Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
    FASCO - Frequently Asked Questions - fasco tool finder
    www.fasco-tools.com/en/faq-manuals.html
    Search Tools by Application ... My Fasco pneumatic nailer/stapler leaks air from the
Feb 09, 2016 | Air Tools & Compressors
Need a cylinder seal 41209 central penumatic nail gun
I have used seals from Bostitch framing guns, however you must experiment. Bostitch seal number T60006 has inside diameter (lip of seal) of 1.875" and seal # N70155 measures slightly over 2". The lip should be about even with the bore of cylinder so that the piston will not push it off. If the seal fits a bit loose, you can apply RTV to inside and push on the seal and install the head. The head valve will center the seal while the RTV firms up. Wait 24 hours or longer before use. Small seal will usually not work; will split or fall off inside gun. Finally, I have made seals using hard roller blade wheel on my small lathe. Roller blace wheels are made of material that will work in oil and is about shore 95a hardness. Good luck.
Nov 06, 2012 | Tools & Hardware - Others
I have a central pneumatic roofing nailer model/sku no, 92917, where can i find replacement parts for it??
Sounds like a Harbor Freight tool. Check your local Harbor Freight dealer for parts, however you'll find that buying a new one for under $80 might be the more logical solution! Hope that helps!
Oct 07, 2011 | Air Tools & Compressors
Looking for a Cental Pneumatic 41209 roofing coiled nailer bucket replacement
Usually the only place for parts for
Central tools is their 800 phone number listed on the document below. That gun was a good copy of the bostitch N12 roofing nailer and also close match to Unicatch roofing nailer. Look on ebay for a photo of the N12 and unicatch. Harbor freight got a lot of returned nailers. Maybe one of the local stores have returned nailers for the ;parts. ;Good luck
http://images.harborfreight.com/manuals/41000-41999/41209.PDF
Sep 07, 2011 | Air Tools & Compressors
I am told by my nephew that my Central Pnuematic #47612 Air Angle Nailer needs a new HD Valve Piston and seal kit. Please advise if you have the parts.
Parts for Central Pneumatic nailers are usually available from HarborFreight.com. Go the their web site and find your nailer. At the bottom of the page for any nailer on their web site, you will find a link for parts sheet, then call the 800 number provided. If you cant find you nailer on their listings, it may have been discontinued. Call the their 800 number anyway to find parts. Good luck
Feb 14, 2011 | Air Tools & Compressors
I have a bostitch model nc65 coil nailer. It is having problems returning the piston to the top position and I believe that a reed valve or seal is missing from above the head valve. I can't find any...
Can you verify the model number please? I only see references to N64 or N66 for coil nailers.
Specific to the problem listed, this is usually caused by an air leak through the O-rings. I would replace the O-rings and make sure that the entire area is well lubricated with pneumatic gun oil and try again. This should resolve the problem.
Dan
Oct 28, 2010 | Stanley Ring Repair Kit KTBO650 for...
Striker/plunger comes down on air nailer as soon as air is applied its a central pneumatic have the parts manual but can not get parts for it
It sounds like the trigger valve is stuck in the open position. Try oiling it and connecting and disconnecting the hose several times. If that won't unstick it, try dismantling the valve and see if you can free it. Be careful -- a nailer with a stuck valve can be dangerous. Central Pneumatic is sold by Harbor Freight and they may be able to get parts for you -- they are decent for parts orders in my experience.
Oct 19, 2009 | Air Tools & Compressors
Aug 11, 2009 | SK Paslode Sk312 Framing Nailer O`ring...
Central pneumatic air nailer leaks air around trigger when trigger is pulled, nailer does not fire
Jun 29, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
433 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
