Question about Invicta Lupah 9818 Wrist Watch
The long second hand on the chronograph will not return to zero when I reset it. What do I do?
2 Suggested Answers
  • 5 Answers
SOURCE: the second hand on my invicta chronograph watch
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Posted on Sep 29, 2010
How to reset Festina back to zero
Pull out the crown, push the chronograph start button. You will see that the hand moves one second. once it is back to zero push back the crown. Depending on your model you might need to pull out the crown with one click for the chronograph timers and another click for the second hand.
Jul 01, 2014 | Festina Watches
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
How do I get the second hand chronograph to move?
The upper push button starts chronometer when pushed once. Second push on the same push button stops it. Lower push button returns chrono hand to zero.
Feb 26, 2011 | DKNY -Dial Chronograph Watch for Women
Want to use larger second hand and set other to zero. have small one working now and the larger one would work if i pressed the top button on side of watch now it wont do anything if i press button dont...
This watch is a chronograph. The true second hand is the one you mentioned that is currently running (what is called the subdial hand).
To use the chronograph hand,
1) Press the button at the 2:00 location to start timing.
2) Press the button at the 2:00 location to stop timing.
3) Press the button at the 4:00 position to reset the chronograph hand(s) to zero.
To reset the chronograph hands to zero, set the crown to either click position one (usually date setting) or two (usually time setting), and use each button to test which subdial hand it will zero out.
Usually it is the first crown click position, and pressing the 2:00 or 4:00 button to zero out.
Warning: Leaving the chronograph function running will drain your watch battery much faster than using the standard second hand, as it is a complication meant for the purpose of timing an activity or other event.
If this does not zero your watch, you must either send it back to Michele, or visit your nearest Certified Master Horologist to assess the issue, as the movement may have a defect.
Feb 25, 2011 | Michele Coquette 71-800-CL-301-72 Wrist...
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
Need to know how to operate Cartier Tank Francaise Chronography W
The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
Do as follows:
1) push the top button once- seconds hand starts moving,
2) push the top button once more- seconds hand stops,
3) push the bottom button once- seconds hand returns to zero.
You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
Do not forget to rate, please.
Jan 10, 2009 | Cartier Tank Americaine W2601156 Wrist...
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Invicta Lupah 9818 Wrist Watch Logo
118 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
