Question about Poulan Garden
I have a Poulan 18in/38cc (50 th anniversary model) chain saw it was a work horse. I cannnot get it started. I removed the old fuel and added new and changed the spark plug and set the gap at 25 thousand. I set the choke and started it it ran for a few seconds and then shut off. Repeated attempts to start with the choke out nad in half way did not get any results. Is the 25 thousand gap ok? The auto matic oiler is not workinmg either. Any suggestions. Bernie
  • Poulan Master
  • 2,239 Answers
You have not actually said what model this is, however, it souds very much like fuel starvation, main things to check are, the filter on the end of the fuel hose in the tank, replace this as a matter of course, now check all the fuel hoses up to the carb, any signs of cracking or fuel leakage and the hoses will require replacment. The oil pump is normally behind the clutch and sprocket, there will be a gear arrangement here whish needs checking, there will also be a pick up hose and filer behind the pump, this may well need cleaning
Let us know how you get on.
Regards Andrew
Posted on Mar 19, 2011
Where do I look to find a model and type number on a poulan chain saw?
The model number is typically the number on the side sticker of the saws pull start assembly....like 2150....etc.
Feb 20, 2015 | Poulan Garden
Can I run an 18in bar on a 16in chain saw
you should be able to without issue.
The Stalling issue started after lengthening the bar/chain?
Dec 23, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Picture sketch
'Bogging down' Incorrect fuel air mix, fuel starvation or air leak.
Jul 31, 2013 | Poulan Pro Chain Saw 38cc, 16in. Bar,...
Ineed the proper mix for gas. for a Poulan pro 262 18in. chain saw.
Hi sephil99125...
50:1 oil to gas ratio
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Sep 09, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have an 18" Poulan chain saw, 25th Anniversary
Yes there is.If you can get the broken pieces out of the tank.there should be a filter on one of the broken lines.you will have too buy some gas line 3/16.take some wd-40 and spray the line.this makes it easier to slide through the hole in tank.then loop it around to gas cap hole and reinstall filter.then make sure filter is at bottom of tank and hook back to carb.
Nov 24, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Gas ratio
Most saws built within the last 30 years or so can be run with 40:1 using modern synthetic saw oils. A number of late model units run 50:1. Make sure to premix the fuel and oil before adding to the saw. Hope this helps!
May 04, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I do not have the manual for this saw, Poulan pp3816 pro 38cc, could not get it to rum, not sure how log it has been since it last ran, put newgas hose on due to it was broke. Saw will start when primed...
A manual can be found here:
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
It sounds as though the fuel system is plumbed in reverse, it should be similar to this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 01, 2010 | Poulan Pro Chain Saw 46cc 20"
38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Dec 05, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
192 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
