Question about Samsung G3 Station Desktop External Drive HX-DU010EC/BW2 2 TB Hard Drive
We have been using a 2 TB Samsung G3 Station External Hard Drive to connect to the TV through a laptop. One day it was working next day no power seems to be going through it. The light doesn't come on anymore when I plug it into the laptop and laptop doesn't read it. Tried different cords. No luck. Any ideas?
    Master:
  • 344 Answers
Assuming you don't hear any activity it might be the power supply that has died. Check if it's under any warrant.. if not you can always rescue the hard drive by taking it out of the enclosure and plugging it into your PC. Odds are it's a SATA drive. Either way.. taking it out of the enclosure will rule out of it's the hard drive or the components. Good luck.
Posted on Mar 19, 2011
Windows 7 64 bit usb
Control Panel, Computer Management, Disk Management. Check that your Samsung disk is present. If it is present, does it have a drive letter assigned? If not Right Click and Assign Drive Letter.
If drive not present you should check power and data connections.
Jan 08, 2014 | Samsung G3 Station Desktop External Drive...
My samsung G3 1.5TB external powered hard drive does not read on my pc. It is very strange has this hard drive reads on my friends pc. The other strange part is that my friend as the exact same hard drive...
tryright clicking on my computer and selecting map network drive.(You'll get thesame results by right clicking on network neighborhood icon on your desktop andselecting map network drive.)This is the method many people use to assign adrive name (i.e.,letter) to a drive.
How about asking you to format it before you can use it?Then you can recover datafrom hard drive withdata recovery software like Tenorshare DataRecovery.It can recover data after deeply scanning your hard drive to look forlost data.
Sep 26, 2011 | Samsung G3 Station Desktop External Drive...
The light is on but the hard drive is not being recognized on the computer or the tv, it was dropped only once. there is a humming sound but no response. no more pictures or movies. is this possible to...
Good Day Daniellevion!
Have you seen a hard disk inside your computer? That is exactly what is inside in an external drive.
You mentioned that you dropped the external drive once, and that could be the reason why your computer was unable to recognized it as external drive.
Danielle! The connectors of the hard disk inside the Samsung External Drive (or other term is hard disk enclosure) might be loosened.
If you can open the enclosure and expose the two connectors, disconnect them and reseat properly.
That might fix it!
Jun 12, 2011 | Samsung G3 Station Desktop External Drive...
I bought the samsung g3 station over the weekend. Partioned using 2 primary partion and one secondary and stored some avi files. @ days later connected the G3 station using the USB and the computer does...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
I used this file recovery program before, quite easy to use and works well for me.
May 23, 2011 | Samsung G3 Station Desktop External Drive...
My 2TB g3 station doesnt wanna work on my mac os x 10.4.11, it says it cannot be modified.
You problem is most likely because the hard disk is formatted using NTFS which can be read on MAC OS but does not allow writing data on it. Solution is to backup your data somewhere and give it a clean format.
Click on the spotlight icon (the magnifying glass) in the upper right corner of your screen, and typing "disk utility."
Once in disk utility, select your external drive in the list on the left of the Disk Utility window, and click "erase". Select FAT32 as your file format, name the volume, and click the "erase" option.
REMEMBER TO BACKUP YOUR DATA as everything will be wiped out during a format!
Mar 03, 2011 | Samsung G3 Station Desktop External Drive...
Is it possible to repair Samsung G3 Station if the USB connector inside the box has been broken?
The adapter board is a common fault, I have had about 20 of these cases in the last year, and It has made me hate external hard drives. My advice, take the hard drive out, its easy enough, remove the top two rubber feet, take out the screws, pry the top open, gently lift out and take the screw out of the adapter board. Now get an external reader. I've just got a cheapo for $50 and it works great for me (http://www.chinavasion.com/product_info.php/pName/premium-dual-sata-hard-drive-docking-station/) but if you want to pay more for something more reliable, I can't blame you. Keep the area reasonably dust free and hard drives you're not using in zip lock bags and you shall have much less drama, trust me.
Feb 22, 2011 | Samsung G3 Station Desktop External Drive...
Hi there. Everyday I have been using my external hard drive. The front lights up when power is on. Today when I turned it on, the fron just flashed and I could not get it working. Just wondering if...
Hi ,
I'm afraid your drive is damaged .
The best way I can think to recover your data is to extract the HDD from it's box ( box will be lost ) and connect the drive directly inside your desktop .
You could also try a recovery tool , from here for instance
http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
Best regards
Jan 29, 2011 | Samsung G3 Station Desktop External Drive...
Samsung G3 Station Desktop External Drive HX-DU010EC/BW2 2 TB Hard Drive Logo
386 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
