Question about Ryobi Garden
I need a manual for a 'Turf Power, Model 780TP'
What setting do I use on a turf king drop spreader to cover 8,140 sq ft?
http://plantscience.psu.edu/research/centers/turf/extension/factsheets/calibrating-spreader
You have given the area you want to spread, but you also need the rate per square foot of the fertilizer. The link above tells you how to calibrate and check the rate of application.
Or you could ask Turf King direct.
http://www.turfking-lawn-care.ca/index.php?option=com_content&view=article&id=107&Itemid=328
Apr 09, 2016 | Garden
What is the correct tyre pressure for
NICE TRACTOR!
Tires
Front Dimensions15x6-6 turf
Air Pressure 110-138 kPa (16-20 psi)
Rear Dimensions26 x 12-12 turf
Air Pressure 96.5-110 kPa (14-16 psi)
Here is a link to the manual - very useful!:
http://manuals.deere.com/cceomview/omtcu29065_j0/Output/Index.html?tM=
Jan 03, 2015 | John Deere Garden
Need a manual for a scott's model 21505x8a lawn mower
You should type that into google, with a space and then ".pdf" You should see some results you can click on to download the PDF owners manual
Oct 06, 2014 | Great States Corp 14 In Scotts Turf Reel...
Turf mode not working
turf mode is where only one wheel is powering the sportsman.
sounds like the left wheel is the one that would drive it.
i can not figure out if it is the rear left wheel but it may be. i would see if there is a problem with that.
Apr 04, 2014 | Polaris 2013 Sportsman X2 550
Mtd turf power tiller
cannot find anything about a 420 tiller... need an actual model number please
Dec 24, 2013 | Garden
Install replacement tires
The tire mounting looks to be pretty standard. Do you have the owner's manual? If not, go to the John Deere website and select to download the operator's manual. You'll need the Decal Model Number: (up to 3 keywords) to search for it.
Sep 22, 2013 | Peg Perego John Deere Turf Tractor
There is no power to the vehicle. The battery is good. Is there a diagram available so that I can check the wiring? I have the John Deere Turf Tractor with trailer. Thank you
how do you know that the battery is good? have you checked the battery and the charger with a multimeter to make sure that it is showing at least 12 volts, if they are here is a link to the owners manual and that has a schematic of the vehicle in it http://us.pegperego.com/admin/archive/manuals/Turf_english.pdf
Aug 12, 2011 | Peg Perego John Deere Turf Tractor
I need a manual for turf tractor by. Pergo
Here is the web site with a link to download the manual.
http://us.pegperego.com/toys-catalog/2010/John+Deere+Turf+Tractor+with+Trailer
Thanks for using Fixya.
Merry Christmas!
Dec 25, 2010 | Peg Perego John Deere Turf Tractor
Garden Logo
41 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
