Question about Cobra HH 38 WX ST CB Radio
Noise in radio hooked direct to battery .had it hooked to my bike radio wiring but lots of noise there moved wiring to battery this helped but still have noise keeping with the RPM of bike motor .
  • 3,018 Answers
You need a noise filter. What is happening is more normal than not. Go with the 20amp rather than the 10 amp and make sure it is up for the job. Here is a link to one I found on Amazon.com for $10 http://www.amazon.com/Heavy-Automotive-Noise-Filter-270-055/dp/B000T306DY Hook it up inline, secure it and say good buy to the unwanted feedback.
Posted on Mar 20, 2011
  • Iron
    Iron Mar 22, 2011
    Glad I could help.
How to get the whinning noise outta my radio in a f-150
Try running the ground wire directly to the battery ground.
Aug 07, 2014 | Planet Audio Peq15 5-band Parametric...
I have a galaxy dx 44 hp was working fine then i moved it to a different truck now getting a lot of background nosie
is it wired direct to fuse box or is it to a lighter plug? the plug will make a lot of ground noise. try different ways until you clear it up. one way is a noise clipper from H +Y
Feb 03, 2013 | Cobra 19 DX IV CB Radio
Battery spills acid, and the engine will not start again after I turn the engine off. I always have to use the jumper cables in order to get it going.
Hi,,,your regulator/rectifier is at fault,,it is overcharging the battery and making acid come out,,you will also need a new battery as the one you have is cooked.
Mar 29, 2011 | 1997 kawasaki VN 800 Vulcan Classic
Lots of engine noise
I would check all connections it might have bin installed wrong
Oct 25, 2009 | Cobra 29 LTD CB Radio
Squeal when motor home running and mike is thumbed
You are getting engine interference from the electronics in the ignition system. First you need to see where its coming in from, The antenna or the power wire.
Turn on the vehicle, and the radio. Then while you hear the noise interference disconnect the antenna.(Do not key the radio) If the noise disappears when you disconnect the antenna, then the noise is coming in from the antenna. Relocating of the antenna may be necessary and or you have bad coax and it may need replacing. If the noise is still there when you take the antenna wire off, then the noise is coming in through the power wire. (this is most likely.)
There should be a setting called ANL (automatic noise limiter, or DSC. Turn this on. That should get rid of it, or make it not so present. If there is still a lot of engine noise then.........
There are only 2 ways around this.
1) Run the power from the radio directly to the battery. This will solve the problem.
If you cannot run the wires to the battery, then you can do the following.
2) Get a ground loop isolator for the power wire. Make sure its not one for the RCA jacks for an audio amplifier. Its made for the power wires. This hooks to where you have the radio connected to now, and then the radio hooks to it.
You can get them from radio shack, but usually they are not in stock and you will have to order it.
You can also check to make sure you have a good ground.
Oct 15, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
My amp is not working! i have a live from battery and a good earth,but still nothing,does it need to be earthed to back of head unit?
Do you have the remote turn-on lead hooked up?
There should be 3 wires on the power side of the amplifier.
Ground - to the car chassis
Power - to the car battery
Remote - to the remote turn on lead from the head unit. (this emits a 12V signal to a relay inside the amplifier for it to turn on when the radio does)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2009 | Car Audio & Video
CB Interference
Alot of times if you can wire it into your fuse panel it will quit anytime you hook up a radio directly to your battery your asking for recieve problems because that is where all your high current items like a blower are connected ( or atleast very close ) Anyway give that a shot . GOOD LUCK Dan
Jul 14, 2009 | Midland 1001Z 40-Channels Base CB Radio
Owners manual for connex 4600 turbo
to cut down on noise i would hook it directly to the battery. make sure there is a fuse in the power cord first.
Robert
Please rate this solution thanks
Feb 23, 2009 | Connex 4600 Base CB Radio
Cobra HH 38 WX ST CB Radio Logo
133 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
