Question about Canon PIXMA MP600 all-In-One InkJet Printer
Scanner will not scan
My scanner will not scan at all. I have tried all the operations that it offers, I.e. scan to pc, etc, but to no avail. I have usd the scanner nly once previously and it worked, but today I cannot get anywhere with it. I have tried unconnecting it from my PC and reconnecting it.
Have you tried scanning using MP Navigator rather than the controls on the printer?
I was having this problem and this worked for me.
Posted on Aug 14, 2008
Driver Scanner 1248ub Driver for win7
Unfortunately, there is no compatible driver for win 7. THe Mustek support center says the following:
Scanners designed to work with older versions of Windows may not function properly after upgrading your computer's operating system.
If Windows® 7 is not listed on the product driver download page for a specific product, no support is offered for Windows® 7. Newer scanner products available will have support for Windows® 7.
Sep 24, 2011 | Mustek Scan Express 1248UB Flatbed Scanner
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
S. Mohan, Chennai, India
Apr 01, 2010 | Canon DR-5010C Scanner
Will not dow load to vista it can not find twin
I think you mean TWAIN.
twain is a sub process that is used to make scanning easier between different applications.
Part of what you want to do depends on the application you are using to scan your document eg word, photoshop, etc etc.
Quite often when you install the software for a scanner it will ask if you want to install the twain components. You should click yes.
I would try to re-install the software for the scanner including any updated drivers from cannon support on the web.
Some applications may offer other methods besides twain to get yoyr scan. If you select one of those and try again.
Hope this helps
Aug 11, 2009 | Canon CanoScan N650U Flatbed Scanner
SOFTWARE 4 HP PACKAARO SCANJET ADF
If you are using WinXP or Vista, the drivers for the device are part of the driver packages included with the operating system. As far as software to operate the scanner, MS Office products include the capability to use an attached scanner to scan documents and images as well as a Document Imaging Tool and a Document Scanning Tool.. Many other packages also offer the same type of functionality. Going directly to the HP site (www.hp.com) and selecting the Support and Drivers tab, selecting the 'download drivers and software' button and entering 'scanjet' and the specific model number of your device can give you any software that they still have available for your product. They have a long list of scanners that they provide DeskScan and Copy software for WinXP/Win2K, etc. The newer ones also have updated drivers and software for Vista users.
Apr 14, 2009 | HP Office Equipment & Supplies
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Fujitsu fi-4120C2 scanner
There are two generally components for a scanner to work, One the Hardware Driver, which connects to the Comp and Two, a program to scan using the hardware connected. Sometimes, both may be available in the same program. For example, after installing the Device Driver, you can use any scanning program, to scan. Hence please check if you have loaded the Device Driver. You may be just using the scanning software, whcih is not able to detect the device!
Jan 20, 2009 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Communication problem with a MP210 Canon Pixma
Yes! No WIA, no scanning! It means Windows Image Aquisition is not turned on... Not only will the scanner not work but also other Imaging devices like cameras. The best way to find out will be to try and scan from Microsoft Paint. Go to Start, all programs, accessories then look for paint. When paint opens, click file then from scanners or cameras. Try to scan, if it scans then WIA is ok.
It means is the scanner software that was not installed correctly so uninstall reinstall just the scanner software! If Paint does not scan, then its your computer's Operating system (winxp) at fault. Make sure WIA is started, or better try to restart that service (in control panel, administrative tools, services, look for Windows Image Aquisition, restart the service).
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Windows Vista Drivers etc
You need to check that whether the scanner is compatiable with windows Vista or not.
If yes download the drivers for win vista for the scanner.
You have not provided the make and model number of the scanner otherwise i could have checked the same for you.
You may go to the manufacturers website of the scanner and you should get all this info there.
If you have any trouble provide me with the make and model number of the scanner.
Hope this helps
Regards
Sammy
Aug 31, 2008 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
old marine
old marine
