Question about Lincoln Welding Tools
1986 onan 225 lincoln welder ..no spark.. switch is good ... how do i check the mag to see if its bad
  • 33 Answers
SOURCE: not a mig a 225 amp lincoln weldanpower just a
check the brushes
Posted on Jul 21, 2009
  • 52 Answers
SOURCE: I have a miller legend welder with an Onan
the flywheel at the front of the engine has a coil reading off of a magnet behind it. ild start there. check battery connections under that panel in the front to make sure battery is able to give all its got. also there is an ignition regulator that does something with voltage and can cause a good mechanic to get a bad headache. its attached to an air shroud. hope this helps...good luck...
Posted on Aug 30, 2009
97F350diesel
  • 1326 Answers
SOURCE: no output from my lincoln ac welder/generator
Check excitor coils, they produce power from the generator head..
Posted on Sep 22, 2009
bubby001
  • 18 Answers
SOURCE: Need a wiring diagram for a Lincoln Welder
try this page http://content.lincolnelectric.com/pdfs/products/navigator/parts/P72.PDF
if ifs not what you looking for heres the service number for Lincoln
1-216-481-8100
Posted on Oct 26, 2009
  • 474 Answers
SOURCE: Need wiring diagram For Lincoln Welder
try the company web site
Posted on Nov 11, 2009
Location of oil switch onan motor miller welder
Hi Martin,
I do have this site that has manual for you in order for you to locate it and its function as well. Hope it helps.
https://www.millerwelds.com/pdf/spec_sheets/ED4-4.pdf
Apr 26, 2014 | Bobcat Miller 225 Welder Generator 907209...
Welding fine , then machine quit welding, would still rev up, but barely arch!
I had the same problem except it was with a miller welder. it was a bad ground connection on the ground cable. if you have an ohm meter. turn off your machine,but do not unplug it. check for resistance from chassis ground on machine to input ground if your input on the machine is good you may have a bad cable,input connection or the ground clamp may not be making a good connection to the cable. good luck!
Dec 21, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
Aug 19, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Welding Tools Logo
181 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
