Question about Injusa Boogie Ride On Car
I brought this bike second hand. I have had it on charge for 3hrs now and no sign of life what so ever. The battery was completly dead when i brought it and i was told it would need a good charge. Was told this could take up to 24hrs. Just worried i have brought a dud car as there is no life at all in it. Am i worrying for nothing or is this a usual thing?
Why won't my phone show any signs of life
needs the battery replaced possibly
Oct 21, 2015 | Samsung Cell Phones
Why isn't my hyosung gt125r dash working?
Bike had stood for a while and the battery was dead, changed the battery, and also replaced the rev counter light, put it back together, no sign of life on the dash.
Aug 23, 2014 | Motorcycles
Lifefitness recumbent bike battery not charging
Possible causes for a dead battery or it not holding charge
1. Battery has lost its ability to hold a charge (dead battery)
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
For any further troubleshooting you can contact our Technical Support Team and we would be happy to help you,
online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Aug 16, 2014 | Life Fitness 9500 HR Recumbent Bike Next...
I have a 2003 ford focus wagon second hand. My battery died out and I thought the alternator was the problem. Brought my car to an alternator repair shop and they said the alternator is still good. I ended...
Lead acid batteries don't like being discharged flat, and it could now be damaged and unable to hold a charge. It does sound as though the voltage regulator part of the alternator is allowing discharge to ground when it should not. You would seem to have a good warranty claim on the battery given they did check the alternator and pronounce it OK.
Nov 04, 2013 | 2003 Ford Focus
I have a 2005 triumph speed triple, a few weeks ago it was haing trouble starting so I replaced it with ngx iridium spark plugs it started right up after I charged the battery. A week later it was...
Check the inline fuse that is normally close to the battery. Also try again with the battery connected to the charger. Most batteries only have a life of around 5 to 6 years, often less on a bike due to vibration.
Aug 02, 2017 | 2005 Triumph Speed triple
My new Compaq CQ56-258SA laptop was advertised as having a battery with a 7hr life but although it has been charged to 100% 4 times now, the battery only lasts 3hrs at the most, Any ideas what I can do or...
The advert is usually for a laptop with the screen set to half brightness, wifi/bluetooth off and only an internet browser open ( no flash content)
However it is important that the battery undergoes a few full cycles.
By cycle i mean fully charge it, then use it until the battery has completely drained.
Jun 09, 2011 | Computers & Internet
My phone is not coming back on
Re4asons for phone not coming on are: Dead battery or dead battery because of dead charger. Use the charger elsewhere to check if it is charging. If yes then use battery elsewhere to see if it has the required charge. If both are working fine then
A dead phone. Or does it show some signs of life like some LED flashing or blinking???? If yes then the phone is not dead yet. It requires reinstall of firmware. Please do that and the phone has a fair amount of chance of springing back to life.
While if there are no signs of life what so ever, then friend the phone may really be dead and can be used as a paper weight on your desk.
Nov 09, 2009 | Motorola Mobility V360 Cellular Phone
Phone went dead. charged it. charge complete. wont
try taking battery out for 30 seconds,then put back in!?
Oct 18, 2009 | Cell Phones
Bike is completely dead
Could be the relay switches such as the flasher relay etc. Wiring could also be the problem. A shorted positive wire on the chassis (negative) can have a negative effect on all the other circuits.
Mar 15, 2009 | 2005 kawasaki Z 750
Injusa Boogie Ride On Car Logo
18 people viewed this question
Top Injusa Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Injusa Toy Expert? Answer questions, earn points and help others
