Question about Gateway FPD2275W LCD Monitor
Can't find a information on where to get a replacement backlight for my FPD2275W Gateway Monitor. Is there a replacement part available.
  • 902 Answers
I couldnt find one looking online. i have seen some for other models but are really expensive. cheaper to buy a new monitor walmart has 22 in ones for 120 bucks. let me know if this helps
Posted on Mar 19, 2011
  • 449 Answers
It can be the backlight or inverter - eBay is the place to go. This is not always a simple job.
Professional service at http://www.lcdrepair.us/
Gateway monitor FPD2275W TFT LCD powers on, gateway logo goes on fine with brightness then monitor brightness drops so you can barely see it. Not sure if this is a problem with the brightness setting or...
The back lamps that provide the illumination of the
colors, is shutting down there are feedback circuits when there is a problem
with the lamps it will shut down the lamps. Replacing the lamps should alleviate
this problem. For more information on this email me at Sprint6@zoominternet.net
Dec 22, 2010 | Gateway FPD2275W LCD Monitor
I would like to replace the backlight bulb on my gateway fpd2275w tft lcd monitor. how do i remove the back (?) case
Very very carefully! or you will break the ribbon cable and it is very hard to put the cable back in the socket. See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
It will more likely to have bad caps, but if you want to change the CCFL assemblies, you will ahev to take the LCD panel apart which very hard to do also unless you have done one before.
Check www.lcdparts.net for lamps.
Aug 30, 2010 | Gateway FPD2275W LCD Monitor
The Gateway FPD2275W TFT LCD Monitor the screen is black when my computer is up & running. I can briefly bring up the screen, and it shows my desk top, then changes to black. I have been trying to...
Hi!
The problem is not the setting on your monitor...The problem is the backlight inverter located inside the upper and lower edge of your screen..
It is busted. The backlight inverter is the light source responsible for the displaying image on your screen. If these were busted.. then the only thing you will see is black screen.
It is very risky for you to replace it by yourself if you don't have the knowledge and the right tools to open the back of your lcd..My suggestion is to bring your monitor to a credible technician to have your backlight inverter replace. if there is warranty for your lcd, please avail this.
Hope it help..
Much appreciated if you rate this solution..thanks..
May 26, 2010 | Gateway FPD2275W LCD Monitor
My monitor fpd2275w gateway turns on but the screen is black
mine does it too...it seems to be that the back light is not staying on...seems to come on full brightness for about 3 seconds then goes out, there are images...but no backlight
Aug 27, 2009 | Gateway FPD2275W LCD Monitor
Monitor is dark
is it brighter if you shine a flashlight on it? The backlight could be broken and needs to be replaced
Aug 13, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Have a problem w/ a Gateway FPD2275 W. When I
This is a common symptom of the backlight failing. Without the backlight, even though the display panel still works you can't see it. The backlight lamp itself is probably OK. It's the inverter circuit that provides lamp power that goes bad.
The usual cause is failure of parts called capacitors in the power supply section. It is possible to open the monitor (not always easy, but possible) and check the capacitors. Often they look bad with bulged or split tops or leakage at the bottoms. Replacing them with parts of the same capacitance rating and slightly higher voltage usually repairs the unit. I've never worked on this particular model, so I can't tell you specific parts. But there are a lot of sites with information on repairing different brands, so a search on the Web may help. There are also youtube videos for some models showing the whole procedure.
Mar 31, 2009 | Gateway FPD2275W LCD Monitor
GATEWAY LCD MONITOR FPD1530. UNIT SHUTS OFF IN ONE SECOND WHEN TURNED ON, EVEN WITH XP SOFTWARE TURNED ON.
Hi...there,
It's seems your backlight inverter are busted... need to replaced a new one or repaired it.
Aug 21, 2008 | Gateway FPD2275W LCD Monitor
Gateway Destination 37" Monitor
Hi...there,
Well... it's mean your backlight inverter it about to be busted. It's time to replaced a new one or repaired it...
Jul 03, 2008 | Gateway FPD2275W LCD Monitor
Uneven backlight in just purchased Best Buy LCD.
my guess on this is either one back light ccfl is cracked/unplugged or the power supply is not running one side of the ccfl back lights, either way you should absolutely take it in for replacement asap
Apr 30, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
