Question about Philips Audio Players & Recorders
No green light on phillips hts3450 subwoofer no audio but have video red indicator on sub when unit is turned off
SOURCE: Can't get sound from the wireless subwoofer
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
  • 54 Answers
SOURCE: Sub woofer flashing red and green
sir,,i think there is something wrong with the connections or the cross over,,,kindly check it out or mjaybe the cone of ur speaker is damage,,,hope too help you thnkss??
Posted on Jan 29, 2008
SOURCE: Always turns to standby
Hi, I was able to take care of this issue by talking to Onkyo tech support. They diagnosed over the phone and concluded that the receiver set the volume for the sub way too low (-12), therefore sub was not receiving the input and was doing what it was supposed to be doing. They walked me through manually increasing the volume and now everything works great.  Good luck! I hope this helps.
Posted on Apr 13, 2008
SOURCE: subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
  • 14 Answers
SOURCE: Wharfdale PC 10 subwoofer
Some basic trouble shooting is required here. First you need to see if it is a problem from your source or the sub. Try a different source to the sub-woofer and see if it changes the response. If still nothing on the sub, then most likely there is an issue with the amp or driver. Check to see if there is a fuse on the sub, if so, it could be blown. There could also be an issue with the auto switching circuit on the subs amp, in that case, it would need to be repaired in the shop. But before that I would check all of the connections to the sub, and also to the driver in the cabinet. If everything looks good, then put some type of source directly to the woofer to see if it works, if you get sound, then looks like the amp has a problem. Again a repair or replace issue.
john
Posted on Aug 20, 2008
Subwoofer not recognized and no sound from tuner
do a test tone which will test all speakers connected to the receiver.
Apr 19, 2014 | Yamaha Audio Players & Recorders
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
Pinout for 15 pin audio connector on Philips
1=control (I assume this is some kind of digital signal to turn the amp on and off...?)
2=nc (no connection)
3=nc
4=centre
5=centre ground
6=digital ground (possibly not needed if you're not hooking into the sub...?)
7=subwoofer
8=sub ground
9=nc
10=left ground
11=left front
12=right front
13=right ground
14=right rear
15=left rear
A full service manual for the HTS3345 is available at http://www.scribd.com/doc/37538958/Philips-HTS3455
Apr 14, 2010 | Philips HTS3450 System
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
Jan 17, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
Dvd player works, but no sound from any speakers
yes, company will charge you, but the best suggestion is to get repaired from the company person.
The normal problems are bad contact of speaker wires and settings of sound from the sound menu. I think you are a genius guy, so you might have checked such things, so now its better to give it to PHILIPS SERVICE CENTRE.
Apr 23, 2009 | Philips HTS3450 System
HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Jan 03, 2009 | Philips HTS3450 System
Psw 3000 sub
I had the same problem. It is a loose conection on the print. The Amp unit goes into failsafe mode. You can check the Rc control. You are only alowed to turn it on and off. No signal regulating.
The solution is to remove the backside, and check the print for bad connections or even broken parts.
I experienced one leg on a transistor tha had broken.
Good look
Aug 11, 2008 | KEF Audio PSW 3000 Subwoofer
Subwoofer doesn't turn on
I felt supid this morning.
I bought a high end cable for my subwoofer.... and it did not work but a regular RCA Cable did. When I went to put the cable back in the package I saw an arrow pointing one way, I turn the cable and it works great.
Dec 12, 2007 | Kenwood VR-405 Receiver
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
