Question about Philips Audio Players & Recorders
Need help hooking it up right - Philips Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
Make and model number first, then the manual. Then (maybe) a solution.
Maybe run it by the manufacturer
Posted on Mar 20, 2011
I have a Bernina Activa 140. The threaded needle is not catching the bobbin thread. What should the needle height be from the plate?
The needle height is best checked by rotating the handwheel until the needle goes down through the stitch-plate (Make sure you're using a zig-zag stitch plate and not a straight stitch plate) and just starts to come back up again. Stop there. Gently push the needle bar to the right until the needle is at its furthest-most travel right (next to the right-hand edge of the needle slot). Tip the machine backwards slightly and drop the bobbin door; take the bobbin out. Open the hook/shuttle retainer, but leave the hook/shuttle in the hook race. The point of the hook/shuttle should be somewhere near the top, just below the stitch plate. Slowly rotate the handwheel until the point of the hook/shuttle passes just behind the needle; The point on the hook/shuttle should be just above the thread hole in the needle - if-so, the needle is at the right height, assuming the machine is properly synchronised. If its at the wrong height, you would need to have the needle-bar mechanism adjusted to put it right (relatively simple) - you cant just try and fudge it by adjusting the needle height using the needle securing screw. If you need help with re-setting the needle bar to get the right height, I can help, but you really need to be sure that the machine is properly synchronised first, so this may not be the total solution. Hope this helps.
Aug 25, 2011 | Bernina Activa 140
I need help
considering that all the wires are hooked up right ,the HU is perfectly ok ,check whether the "Fader"is selected to the front speakers .
May 31, 2010 | Pioneer DEH-P4000UB CD Player
I need a rafter hook for a Porter Cable nail gun
yeah good luck finding one that fits. I have been looking for 8 years. If I remember correctly the hooks that are sold for frame guns, the hole is to big for the fitting, so what I di is got a new fitting with longer threads and some washers i want to say like 3/4 or even 1" diam. With the right size hole and sandwiched the hook between them. It works well enough, the down side is the the hook will be in a fixed position. So if your right handed the you need to tighen it down so the hook is about 45 to 60 degrees left of center so you will still be able to load nails. hope this helps. Ohh and if the hole in the hook is to small just drill it out and presto. I have had so many frome guns I forget what works on what gun but I think you will find that this is the trick.
Feb 25, 2010 | Porter Cable FR350A Factory Reconditioned...
Spring hook-ups throttle free design carb.
Spring goes from throttle air valve to plastic lever under flywheel. Cooling fan on flywheel provides pressure to open/close throttle. As engine (fan) speeds up, pressure on lever causes throttle to close. As engine slows, throttle will open. System achieves an equilibrium very quickly.
hope it helps!
May 30, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
1990 honda accord
If it is a three wire ox sensor then you must make sure that wires are hooked up right or it will not function and cause engine to run erratic. One of the wires are for the preheater in ox sensor so it must be hooked properly.
Aug 09, 2008 | 1991 Honda Accord
Panasonic cq-c3100u
scottmar7- You need the wiring diagram for your panasonic deck,the diagram is as follows.
red- 12volt key switched
yellow-12volt constant-memory
black-ground
white-left front positive
white with black stripe-left front negative
grey- right front positive
grey w/black stripe-right front negative
green-rear left positive
green w/black stripe-rear left negative
purple-right rear positive
purple w/black stripe-right rear negative
blue- remote turn on- for amplifier
These are all the wires you should need,to hook up you deck.
If you need anything else let me know,I can help you,happy listening. cooltek mar,14/08
Mar 14, 2008 | Audio Players & Recorders
Which ports should my front speakers go into?
you should use only a ( left & right) or b ( left & right )for your speaker connection.can not mix . hope it help.
Aug 11, 2007 | Denon AVR-2807 Receiver
13 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
