Question about LG Refrigerators
I just bought an LG refrigerator, Model LSC27921. The freezer compartment is too cold. How do I adjust the settings to make it just slightly warmer?
fridgetech
  • 473 Answers
SOURCE: my freezers works but my refrigerator
Three things likely to cause this problem. 1. Defrost problem: will see frost build up on back panel in freezer. 2. Bad evaporator fan. Listen for fan noise in freezer (may have to hold door switch closed depending on the model). 3. Bad damper motor (vent to fridge) if fan is running check for air flow out of that vent. These are the most common. See what you can find and let me know. Then we can take further steps.
Posted on Oct 07, 2007
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
kram26
  • 544 Answers
SOURCE: refrigerator does not get cold enough 50 degrees.
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks.
Posted on Mar 31, 2009
rafaelrs38
  • 12 Answers
SOURCE: freezer and refrigerator stop cooling, back of
clean all the dust and form the gril on the back of your frig
Posted on Aug 10, 2009
  • 3 Answers
SOURCE: refrigerator compartment is warmer than usual.
check the condenser fan on the back for proper operation, these can cause cooling problems, and are prone to failure.
Posted on Mar 30, 2010
Refrigerator is not cold, but Freezer is too cold
You can adjust temperatures of both the compartments via regulators at the far end of the fridge compartment. you can set the temperature from there. sometimes they are also on the side panel. hope this helps. This might be helpful too http://www.wikihow.com/Set-Your-Refrigerator-Temperature
Aug 22, 2013 | Whirlpool GB2SHKXL Bottom Freezer...
The motor starts, the fan works, no freezing, just slightly cool air coming from freezer compartment, changed relay, problem persists LG electrocool Model GM 3138c
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | LG Refrigerators
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
Mod ED27DQ side by side refrigerator-Freezer works fine-refrigerator will not cool below 45 degrees
check the damper door located between the freezer and refrigerator compartment,if it is iced up it cannot open up and let cold air into refrigerator compartment from the freezer compartment,deice this part and then adjust the refrigerators cold control and see that the door opens and closes with controls adjustment
Jan 31, 2010 | Whirlpool Refrigerators
Amana DRB2201CW refrigerator does not get cold
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Jul 28, 2009 | Amana ARB2257CSL Bottom Freezer...
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
