Question about Maytag M7DH65B2A Dehumidifier
After the first year of owning this product it trips the breaker every time I turn it on. I have tried plugging it in to a different circuit and does the samething to that breaker also. What should I try next.... ?
    Brigadier General:
  • 4,736 Answers
From what you described there is an electrical short or overloading problem within the dehumidifier.You should also check the cord and the plug from the unit, to be sure it's not worn or cracked. Look at the prongs of the plug. Are they damaged or bent?
To really attempt in-depth troubleshooting, you will need your Owners Manual , which hopefully would show a wiring schematic and a multi-meter circuit tester. I can tell you this, your humidifier was not manufactured by Maytag, It was manufactured by Fedders for Maytag.
The easiest thing you can do yourself, is check the the above, as well as filter (Does it need cleaning?) Remove the bucket and inspect the trigger mechanism for wear or damage. And if all else fails, contact Bob McIvor, Service Technician, 609-662-5323 for the Fedders Company. If you have your Proof of Purchase, there may be some warranty coverage left for parts, if needed.
Posted on Mar 20, 2011
Starting tripping circuit breaker
Good Afternoon Dennis - Often when this occurs, it is because there are too many appliances on the circuit or something may have a weak or poor breaker. Try plugging the unit in a different location or on its own circuit. If the issue continues, then it could also be possible that something shorted within the unit. So in this case, because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage. Thanks for allowing me to help you.
Jul 28, 2013 | Frigidaire FAD504TDD Dehumidifier
I have a Kenmore dehumidifier 580.54701. It worked fine for two years, but now when it is plugged in and you hit "on" nothing happens. I took it apart, but cannot tell what is wrong. Do you think...
It could need replacing or the outlet that the unit is plugged into is at fault. Check you main circuit breaker panel, to see if a breaker has been tripped. Also, check the outlet's receptacle for internal damage or a loose or broken wire. In addition, try plugging it into another receptacle that is on a different circuit, than the one it's plugged into now. All these things are part of the process of elimination, in troubleshooting and finding the problem.
Hope this helped you. Please let me know. Thanks.
Jun 04, 2011 | Kenmore 54501 Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
Dehumidifier trips breaker
compressor problem. Talked with coworker who had the same problem. He brought his in for repair and was told the compressor needed to be replaced. The cost of compressor close to the cost of a new unit so time for a new one.
Mar 25, 2009 | Haier Dehumidifiers
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
Aug 22, 2008 | Whirlpool AD65USL / AD65USM Dehumidifier
Circuit breaker
SOUNDS LIKE TO ME THAT YOUR DEHUMIDIFER HAS A SHORT. SOME TIMES ITS THE PLUG OR THE CORD BUT MOST TIMES IT GETS OXIDATION FROM MOISTURE INSIDE.
Jun 24, 2008 | Kenmore 53509 Dehumidifier
Trips the circuit breaker on start up
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
Oct 17, 2007 | Goldstar DH504EL Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
51 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
