Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I HAVE A NEW OPENER AND WHAT TO SET UP OLD KEY-LESS GRAGE DOOR ENTREY PAD WITH THE NEW OPENER. i MUST HAVE LOST THE INSTRUTIONS
    President:
  • 3,197 Answers
If the keypad is older than April 2005 it will not work with your new opener. Otherwise follow these instructions.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Mar 21, 2011
Cannot open drivers door of my 1996 honda crv automatic using key or from inside. having to climb over from passenger side to drive and get out again.
Sue we arn't talking keyless entrey here .
Then if the key works in the other locks it must be good not worn out .
Witch leaves the lock cylinder on the drivers door or the mechinizam that moves the rods inside of the door to lock and unlock it .
Dose the key feel like it fits ok and the lock turn normally .If so that leaves the mechinizam inside the door .
Its not the end of the world likely something popped off or a little plastic clip broke that holds the rod in place .
The door needs to be taken apart from the inside witch means it needs to be open to repair .Its like a caught 22 can't fix it unless its open but can't open it .
There are ways slim jim or the old coat hanger way if you can roll the window down think about it do a little reserach it can be opened with out distroying the door
Apr 24, 2015 | Honda CR-V Cars & Trucks
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Lost keys for 1999 jeep grand cherokee how do i
only the dealer can repair this, the Body control computer must be programmed to the new lock cylinder, there is no way around this.
Aug 16, 2010 | 1999 Jeep Grand Cherokee
Old key pad can you
If your keypad is older than April 2005 you will need a new one.
Dec 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
I am purchasing a home that has a Champion 1/2 hp garage door. Nobody knows the key pad code to open the door. How can I reset the code to use it and where should I buy the remote garage door opener?
Hello there if you go to www.champion.com there is a area in there that deals with your grage door and support numbers to call for technical assistance too ok
best regards mike
Aug 06, 2009 | Kitchen Appliances - Others
Combination on car keypad does not open doors
Does the key pad on the door light up? Are there any tears in the key pad numbers? Does the key pad lock the doors?.
There are no fuses directly for the pad.. The key pad is linked directly to the RAP. module. If the locks work from the FOB the fuses for the Module are good. Chances are the pad is no good especially if it don't light up. The RAP module is above the driver side foot well, directly above the accelerator pedal . Hope this helps.
Mar 09, 2009 | 1999 Ford Taurus
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
32 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
