I've got a Goodwin clj24-1c model unit. Had a service guy come out and refill the freon last summer in october. Shortly after it went out and we havn't had the money to worry about it... and now its hot. I went out and checked it out and found a hard start capacitor shoved back into the unit where it wasnt orignally and the thing is fried. Would this stop my unit from blowing cold air?
  • Revefr3 Mar 19, 2011
    Dear Scottness84,
    If you have the bill the last serviceman gave you, does it list that hardstart as part of what he did? Either way, the answer to your question is yes, it could cause your unit not to start. The first thint I would ask you to do is shut off the power to the outside unit. Set your thermostat to it's coldest point (just for now). Before you turn the breaker back on, remove the burned out hard start as it is not supposed to be needed. Turn the breaker on and listen. You should hear the fan start and see the blade turn up to speed. At the same time you should hear the compressor start. It will start out as a mechanical growl and then begin to quiet somewhat. If all you hear is a hum, then shut the breaker off as you either have a bad "Run Capacitor" or a locked up compressor. The "run capacitor is grey or silver in color and may appear swollen. Also, if you are able to get to it, make sure the wires are attached to all three terminals on the compressor itself. Many compressors have been condemned due to burned wires. I hope this helps.
  • 4 Answers
Dear Scottness84, If you have the bill the last serviceman gave you, does it list that hardstart as part of what he did? Either way, the answer to your question is yes, it could cause your unit not to start. The first thint I would ask you to do is shut off the power to the outside unit. Set your thermostat to it's coldest point (just for now). Before you turn the breaker back on, remove the burned out hard start as it is not supposed to be needed. Turn the breaker on and listen. You should hear the fan start and see the blade turn up to speed. At the same time you should hear the compressor start. It will start out as a mechanical growl and then begin to quiet somewhat. If all you hear is a hum, then shut the breaker off as you either have a bad "Run Capacitor" or a locked up compressor. The "run capacitor is grey or silver in color and may appear swollen. Also, if you are able to get to it, make sure the wires are attached to all three terminals on the compressor itself. Many compressors have been condemned due to burned wires. I hope this helps. Sorry I posted in the wrong place at first
Posted on Mar 19, 2011
  • scottness84 Mar 20, 2011
    Ok I did as u said, turned off breaker, and turned it back on. Fan starts right up and i sounds like compressor is starting , then all i hear is fan.. and not blowing cold air. That mean i need to replace the hard start capacitor? It wasn't on the bill by the way, he just filled freon and gave my wife some line about how its old the bottom was rusting out and ruining the entire unit, and how he could put in a new unit for 3k dollars to save us from a blown up house. No offense to service techs but this sounds like the same **** i hear when my wife takes our cars to the shop.
  • Revefr3 Mar 21, 2011
    at this point, I have to suspect the "run capacitor" I mentioned before. I will either be grey plastic or metal. With the power off, try to locate the wires coming from the compressor itself. There will be a yellow or purple wire attached to one post on the run capacitor. If the capacitor has two sets of contacts, it is for the compressor alone. If there are three sets of contacts, then the capacitor is for both the fan and the compressor. It is not uncommon for one side to go bad and the other be ok. I agree, it sounds like the guy is just trying to get your money.
    If there is any oil on the outside of the capacitor, or if it is in any way swollen, those are the tell-tale signs of a bad capacitor.
    Please let me know how you make out. The fact that the compressor tries to start tells me that all is not lost.
Should fan run all the time on ff80g freezer fridge not cooling
I've had this problem before. I am not a refrigeration expert but when I called one in, he told me that the refrigerator was out of Freon.
He replaced the Freon and the unit started cooling again but it didn't last long. He came back and found a leak which he repaired. I didn't have any more problems with this unit and eventually traded it in for a new one several years later.
The repairs were not expensive but the service call was. Fortunately, he only charged one service call for both trips because the original repair didn't hold up and he only charged me for one Freon refill.
Mar 16, 2015 | Hotpoint Refrigerators
What would cause oil to turn milky white?
That is the typical color when water is mixing with the oil.
Probably a leaking seal or gasket.
The washer will need servicing.
May 05, 2014 | Simpson MegaShot 3100 PSI Gas Powered...
600 series Penquin rooftop unit
could be possibly low on freon and they are self contained units you can put a saddle valve on it and try to put freon in it. If its r22 its the high dollar freon.......have an experienced hvac guy come out.
Jul 08, 2013 | Dometic Rooftop RV Air Conditioner
Sharp CV-P12Px not cooling
Sounds like an issue with the compressor. Have a service technician test the compressor.
Apr 30, 2012 | Sharp CVP12PX Air Conditioner
Keeps saying prime. I've unplugged and restarted, refilled resevoir.
I unplug the unit and it reset. The Prime light went off.
I unplugged mine and the unit reset and the Prime warning went off
Http://www.buyicemachines.com
Feb 28, 2012 | Keurig B60 Coffee Maker
Other than replacing air filters, what else must be done to keep air conditioners working properly. I,ve used the same air conditioner for many years, but have never had it serviced. Does it need freon?
Only a qualified service technician can tell you if the unit needs to be recharged, by testing in the input and output pressure. It would be a good idea to have it serviced professionally, since it's never been serviced. It could be money, well spent. Or it could be a Long Hot Summer without the AC.
May 29, 2011 | Friedrich Heating & Cooling
The compressor on my Danby dehumidifier turns on for a few seconds, very weakly, and quickly cuts out. The fan and control panel are all working properly. The humidity is high enough for it to turn on...
Sounds like you've lost a lot of freon. Find the pump on your unit. Be careful, but after running it a while, touch the tube somewhere between the pump and cooling coils. If it is not hot then you have lost fluid. What happens is under normal working conditions the compressor would compress the freon making it hot, which then gets cooled by the radiator coils. In your case, there isn't enough fluid to compress to make it hot. Unfortunately, you need to have it refilled by a repair shop. Try your local A/C or HVAC shop. Don't be surprised if they can't refill with freon as it's bad for the ozone and being phased out.
May 04, 2011 | Danby DDR586R Dehumidifier
Duo therm ac problem
Same problem. I have a 2005 on a Rockwood Roo. Worked fine in October 2009. Not working June 2010. Problem is not a freon leak, compressor went bad. I banged the compressor gently with rubber mallet then with a hammer but that did not work. The fan runs, the compressor runs but gets hot. Also no indication of freon moving through system as everything gets warm from the compressor outward.
Aug 25, 2008 | Dometic Rooftop RV Air Conditioner
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
