Question about Dell Studio 17 Laptop
Battery doesn't appear to be charging. - Dell Studio 17 Laptop
    Problem Solver:
  • 9 Answers
There may be several physical problems. You should make sure that the battery is properly plugged in and no switches that allow it to be removed are in the open position. Checking that the power cord if plugged in proper at the laptop, the power brick, and the power outlet may also solve the problem. If none of these work, try using a different power cord that fits your laptop if you can get your hands on one. You may also want to try a different power outlet, or make sure that power outlet can power another device (eg vacuum, phone) so you know if it's actually a problem with that power outlet and not your computer.
If you battery doesn't charge even with a cable that you know works for another computer, and the outlet is working properly, your battery may be corroded or suffering from over-use over a long period of time. In this case it would be best to buy a replacement battery directly from Dell which you can do here:
http://www.amazon.com/Replacement-Laptop-Battery-Studio-7200mAh/sim/B003FZ33SS/2
Posted on Mar 19, 2011
No Power
If your Charger is OK, then the problem is your units' battery was drained. Change your units' battery.
Apr 23, 2013 | JVC GZ-EX210 Full HD Everio Camcorder with...
Battery on lg shine not charging and not showing how much battery life is left
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 02, 2012 | LG Shine KE970 Cellular Phone
Samsung n145 battery is not working
allright,battery not charging right? it's might be that the battery itself working properly,but the system doesn't indicate that the battery is charging,because of error in the battery management software,in order to fix the software,you need to reinstall the software by using device manager,to Open device manager,right click on My Computer,and select Properties,when the Properties windows appear,click on the Hardware tab,and you will see Device Manager button,click it and Device Manager window will appear,or you can go to Start,and type Device,then select Device Manager
Expand the Battery category,and right click on Microsoft ACPI Compliant Control Method Battery listing,and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes .
Aug 27, 2012 | Samsung N145-JP01US Netbook
My samsung intercept will not charge do to "battery temperature" is there a way i could clean the battery or bypass this somehow?
First Option:
Second Option:
Aug 20, 2012 | Samsung Cell Phones
Battery will not charge
First Option:
Second Option:
Aug 14, 2012 | Samsung Intensity II U460 Verizon
The battery isn't charging
First Option:
Jul 24, 2012 | LG Accolade VX5600 Standard Battery
Batteries seem to be low but charger doesn't appear to be working
Easy you just need to replace your Batteries your charger will not charge bad batteries so that's why it seems like that in most cases, now it also could mean you have a bad charger as well.
Aug 25, 2011 | Pride Maxima 3-Wheel 3-Wheel Scooter
Won't turn on
Firstly try recharging, if the battery doesn`t hold its charge then replace.
Some phones when the battery is flat it can take a while for anything to appear on the screen.
Oct 25, 2009 | Nokia 5310 Cellular Phone
Dell Studio 17 Laptop Logo
129 people viewed this question
Alun Cox
