Question about Belkin Computers & Internet
Trying to connect online with a new computer thru your wireless router. The computer(Insperon 530) doesn't recognize the connection. Techs are telling me it's the router. The router is working fine on two other computers in the house.
    Scholar:
  • 67 Answers
Did you change the discovery options in Vista or did you leave it to the default. vista has the discovery map viewer if you can't see your router listed in this viewer then you have a problem. I ran into the same thing you're going through now.
This is what I did...
click on each one listed below
1. Flag
2. Network
3. first network view every network pc should be listed along with the router if not let's continue on
4. network and sharing center
5. network should be private not public for one thing
6. vista has IPv6 and IPv4 XP just had IPv4 (this allows you to change the DHCP)
7. manage network connections (right panel)
8. properties
9 everything in their should be checked off, but if you're having issues you might want to uncheck
10. IPv6 and just use IPv4.
I use both and havn't seen any issues
Now leave that popup open and go back to Network and Sharing Center
Under the section called Sharing and Discovery (it should look like this)
on
on
off
off
on
off
What does the full map view show?
Should be your computer name, the wireless router or wireless access point and the internet globe
Way below that are the list of PCs on the network.
Make sure your wireless encyption is set to either WEP64-128bit if you have WPA/WPA2 use those harder for anyone to break into the WPA/WPA2 than it is with WEP keys.
Change the performance speed to 54Mbps for the wireless nic. To do this under Vista you need to go back:
to network
managed network connection (left panel)
right click on your wireless network connection
click on properties
click on configure
click on advance
change Rate/speed whatever it's called to a Value: 54 (don't use best rate or etc)
If you don't see this last feature mentioned then, go to your laptop maker web site and get the latest driver for that model.
Note: You should see 5 bars all lit up green. If you're see less then your wireless connection signal is weak. To fix that you
need to add wireless access point nearby. Otherwise the 54mbps won't be available always you'll see less than that.
If you're using N set the router for N speeds from 240 to 270mbps even though N is rated at 300Mpbs.
If no go above then goto below
Download the latest drivers from DELL and then uninstall the ones you have now. If the drivers are the same drivers you have. Then uninstall them anyway and reboot the laptop. If Vista doesn't see the or install the drivers then you just do it. Now make sure the follow is set up above.
Other than all of the above it's either a bad wireless NIC on the motherboard or the OS needs to be re-installed. These are the final methods but since this is new DELL should service the laptop for free. That's if you have to go that step.
Posted on Aug 02, 2008
Wifi connection
The Lexmark X2600 printer does not support wireless connectivity because it doesn't have a wireless network adapter. Another indication that the printer does not support wireless connection is that it doesn't have a wireless medallion symbol in front of the printer used to indicate wireless signal.
Dec 12, 2011 | Lexmark X2600 InkJet Printer
Cannot connect my dell laptop wirelessly, will connect with a wire and will connect wirelessly at the library. The old 2wire was ok but we replaced it with a new 2wire today. Have spent 3 hours with att...
Since you are able to connect using a hardwired connection and you're able to connect wirelessly at the library, that simply means that your computer and your internet browser are fine. where is your wireless computer and your wireless located? are there any possible wireless devices interfering with the wireless signal like chordless phones, cellphone, TVs, radios, microwave oven? are your walls in your house covered with metal plates coz that would really make the signal deteriorate. the settinngs on your wireless router may also need to be reconfigured and boost up the signal of the wireless router.if only i could remotely access your wireless router, I would really walk you thru on what to check on your wireless router
Jul 07, 2011 | 2wire (1000-000057-000) Modem
I am trying to set up my wireless router using the cd and following the sequence of powering up the modem, the computer and then the router.. when i connect my router to my modem and computer and power up...
Make sure you follow the instructions on the cd to a "T", do not do anything with hooking up cables until the cd tells you to. I think you may have jumped ahead and the computer and all do not recognize
each other.
Feb 16, 2011 | Linksys Wireless-G WRT54G Router
My network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
Mar 09, 2010 | Netopia (3347NWG-VGX) Wireless Router...
It lost its LAC and right now my computer is running on the wireless even though it's not wireless.
Your router's cable is connected in the wrong connection.
1. Remove the cable from the wireless connector
2. Insert it into one of the ports of the router that has LAN not WAN.
3. You will be able to connect your wireless and wired computers to the router.
This could have blue for WAN or Yellow for WAN and then the rest can have yellow for the 4 PCs to connect.
Sep 28, 2009 | Dell Inspiron 530 Desktop Computer
New laptop, connected to router, no connection to internet
Your DHCP server is either disabled or have not enough room for anymore computers. set the number of ips to "more" than what you need ie 3 or 4.
Nov 23, 2008 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
Internet connection
What is the model or the brand of your modem from Verizon?
Can your computer get online if its wired to the router?
Jul 21, 2008 | Linksys Ultra RangePlus Wireless Routr...
The Computer doesn't recognize the Router (And Yes. the wireless switch is turned on)
DON'T use the software.
Are you trying to connect by way of ethernet cable or wireless?
Either way you do it, you do NOT need that crap software. 90% of the time, that software interferes with everything. Up to AND INCLUDING preventing your system from connecting to the router.
Before you can get any help with this, you will need to give us more information about your setup.
NOTE: We CAN NOT POSSIBLY figure out all of the variables if you do not give them to us. So don't go marking my post as "Thanks for trying" just because your problem is not solved in the first post.
Instead, if you want answers, you're going to have to be more specific.
I see a Linksys WRT54G wireless router. Is there a version number on there?
Example: WRT54G v3 (Mine.)
You're also going to have to tell us more about your computer. Is it Windows XP? Service Pack 1/2? Windows Vista? Linux even? (Give model numbers if it's a pre-built system from an OEM manufacturer such as HP, Dell, etc.)
Then there's the internet connection. Cable internet? DSL? Satellite? Give us MODEL NUMBERS of the equipment they have issued to you for your internet connection.
Then tell us how you have things connected. Wireless? Ethernet cable? What is connected to what?
See what I mean?
FULL details bring quicker resolution of your problem. I will be monitoring this post as you seem capable of providing this information to us. When I see more complete information, I will help you further from there.
Thanks. :)
Cyryl
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
51 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
