Question about Canon ZR-950 Mini DV Camcorder
Our Canon ZR950 DC 7.4v should have a record mode and a play mode, and you switch a button to go between one to the other. Today we no matter where the switch pointing (play or camera) , we can only get the play mode to come up--there is no record mode to be found. It is extremely frustrating because the camcorder is less than 2 years old.
  • 2,574 Answers
Try this:
1.Change the position of the protect switch on the MiniDV cassette tape
2.Rewind the tape on the camcorder or insert a new tape
Posted on Mar 19, 2011
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
    [PDF]Manual
    gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
    Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
    Canon S3 IS Review: Full Review - Operation
    www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
    Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
    [PDF]Download
    galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
    Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
    How to give your low-end Canon digital camera RAW support
    archive09.linux.com/feature/118946
    Linux.com
Jan 24, 2016 | Canon PowerShot S3 IS Digital Camera
Hi, I have a Canon Powershot A700 digital camera and I am facing a problem with it. The 'Mode Switch' button, which changes the mode from Shoot/Record mode to Play/View mode is not working....
If you have the manual for this camera turn to page 15.
This tells you how to switch between Shooting Mode and Playback Mode.
This is achieved simply by pressing the DISP button.
This button is located below and to the left of the FUNC/SET button.
Pressing DISP repeatedly toggles between Shooting Mode and Playback Mode.
I would suggest you try these steps with your Mode Switch in both positions alternately.
May 20, 2011 | Canon PowerShot A700 Digital Camera
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it)...
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Nov 13, 2010 | Canon VIXIA HV30 DV Camcorder
I recorded a MiniDV with a HD camera the Canon HV30 to be specific. When trying to play it back on my Canon zr950 i get an error message. Will my tape only playback on an HD video camera? What do I do?
Canon ZR950 is an older Standard Definition camera that records in DV format, and does not recognize HDV format recorded by HV30.
HV30 can be switched to DV format, which should be playable on ZR950.
Dec 10, 2009 | Canon VIXIA HV30 DV Camcorder
Bars across picture when replaying tapes.
The tapes were recorded in LP mode and the replay is set to SP mode. Switch from "EASY" to "P" and replay and you should be OK
Apr 27, 2009 | Canon MV800i Mini DV Digital Camcorder
Canon A430 will not record
check for a hold switch...and unlock (may be hard to find!
Dec 11, 2008 | Kodak EasyShare One Digital Camera
I have a Canon zr950 mini DV cam corder and when I connect the DV cable I do not see the picture on the preview screen on the PC. Drivers installed and it recognizes the cam.
I just discovered that this is the same reason I could not transfer the video for my cannon ZR950 the menu options on the cam has a setting to turn tv on and off
Aug 07, 2008 | Canon Cameras
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Sep 09, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon ZR-950 Mini DV Camcorder Logo
240 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
