Question about Cambridge Audio Azur 650a 2Channel Amplifier
I just bought the Cambridge 650A amp. The sound is great, however, it annoys me that the amp will go to Protection (3 bursts- out of operation range) when I swithch on the amp (either from standby or power on). I need to switch off the amp for several times until it warms up and then I can enjoy the music. I tried to take off all the input and output wires, the situation is the sam. Is this a fault?
2 Suggested Answers
Grubhead
  • 5515 Answers
SOURCE: Just set up my brand new cambridge audio azur 650a
Just make certain that the connections are all good with no wires touching. If it still doesn't perform after that return it to where you bought it and get a new replacement or your money back.
Posted on Feb 19, 2011
Why does my Cambridge Audio Azur 851W power down even when a signal is operating.
amps like this only power down when there is a problem with the amp, usually a shorted output stage, but could also be shorted speaker wires or damaged speakers, it's a self protection mechanism
do you get sound from both speakers before it powers down?? if you do it is definitely an internal problem so take it to a repair facility,,,
if not check the speaker cables & the speakers themselve
Feb 22, 2015 | Cambridge Audio Audio Players & Recorders
Cambridge Audio Azur 650A service manual
try:
http://www.excelia-hifi.cz/cambridge-audio/manual/cambridge-audio-azur-550a-650a.pdf
Is the user manual try the OEM for the service manual, most OEMs will require you to be qualified to do the repair.
Oct 04, 2014 | Audio Players & Recorders
Protection light flashing
If Richer Sounds can't detect a problem with everything disconnected and protection indicated, you need to find another repairer.
Jan 23, 2018 | Cambridge Audio Azur 650A Integrated...
Running four S70 Siroccos off the amp, everytime volume gets halfway the protection is cutting in with protection light flashing three times? When reducing down to two speakers amp cuts out three quarters...
You are overloading your amp. IMO 640A cannot handle heavy loads.
Better change the speaker combo and connect something that puts right load on the 640A. Else, get a meaty amp from CA.
Mar 04, 2011 | Cambridge Audio Azur 640A Amplifier
Just set up my brand new cambridge audio azur 650a amplifier. It keeps cutting out with the protection light blinking three times indicating "overvoltage" according to the manual. I'm using it at...
Feb 16, 2011 | Cambridge Audio Azur 650a 2Channel...
Amp keeps cuting out when you increase vol
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 30, 2011 | Cambridge Audio Azur 650a 2Channel...
The amp won't power up. The cord is is, the power is on, but when I press the Standby/On button, the MP3 LED blinks a few times, then it goes off and all the LEDs, from the protection, speaker A, B and so...
Hi... If all the speakers are connected properly then I would say, there is a failure in either the power supply filtering caps or one output has failed and it's going into Protect mode to keep from frying the speakers
It will require service at that point.
Aug 21, 2010 | Cambridge Audio Azur 650a 2Channel...
I have cambridge audio azur 640a amp. Problem I have is only the one speaker is working. Both speakers seem to be ok working off the left speaker terminal. Seems to be problem with output from right...
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Dec 29, 2009 | Cambridge Audio Azur 640A Amplifier
Cambridge Audio Azur 650a 2Channel Amplifier Logo
77 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
