Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon iP4300 printer: Error code 1250 says paper output tray is closed. Manual says, could be paper jam. there is no paper jam and output tray is open. I turned on and off. Re-tried several times. Same error code. Any ideas?
4 Suggested Answers
SOURCE: Printer Error
Paper tray was forced down accidentally and broke the trayswitch actuator part of the right hand door hinge. Superglued a small piece of plant label plastic (5mm x 12mm) to the top of the hinge. This then presses the switch actuator when the paper tray is down. The topcover can be removed by pressing the "hooks" - two front_under, two rear and one each side with a small flat screwdriver through the slits. Disconnect power & USB cables first!
Posted on Aug 04, 2009
ic0729
  • 212 Answers
SOURCE: canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Posted on Mar 19, 2010
hattinghbr
  • 214 Answers
SOURCE: error 1250
look for a small sensor on you right hand side. it tell the m/c if it is open or close. it migit be stuck.
Posted on Nov 04, 2011
Paper outray is showing closed however its open, in Canon mp287 printer
For Paper Output Tray error
Paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
or
look for buttons or such things on the part that has blue rectangle below.. check inside if theres piece of paper or any object.
Jan 30, 2015 | Canon Office Equipment & Supplies
Error 1250
Nov 04, 2011 | Canon Pixma iP4500 InkJet Printer
Jammed paper removed flashing green and yellow error code 6A00
6A00 meens jammed paper. Check that there is nothing inside, take the paper tray all the way out and look inside. Unplug the power, the take it back in and turn on the printer to see if that solves your problem.
Jun 05, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 printer says paper output tray is closed. wont prin
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer Error
on the ip4300, the clips that hold the front of the cover on are on the bottom, not the front as shown in the service manual for the 4200.
May 21, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
PIXMA ip8500 not printing
i have a pixma ip4300 i keep getting the error number 1250 "paper output try is closed" but infact its is open i have tried opening and closing and restarting and everything else i can think of. any ideas of what to do?
Jun 23, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
1,064 people viewed this question
old marine
old marine
