Hello, i have a Aoc 2434pw monitor that just lost all its power, it was on overnight as usuall (online business so my pc never shuts down), but i woke up to find that all power to the monitor was not working. I unplugged the monitor from the pc and plugged in a different monitor which worked so it is not the video card. after that i unplugged the power cable for the monitor and after 15mins, plugged it back in and it does not show any power at all.... no lights nothing, it is completely dead ...... i will replace internal parts if needed, so please any info on this problem would be great. thanks . Ronald
    Novelist:
  • 144 Answers
Many flat screen monitors were manufactured with faulty capacitors.
See if you can open the monitor and examine the power supply for any "domed" capacitors. The top of the capacitor should be flat, but if pressure has built up inside, they become domed, indicating that they have failed.
Replace any of them that you see to be damaged and there is a good chance that the monitor will work again.
It has been a problem with quite a number of monitors. The electrolyte inside the capacitors was cheaper and just doesn't hold up.
Good luck
Posted on Mar 19, 2011
Why rca 19la30rq is shutting down after 1 second?
The problem could be a failing power supply. It starts up but can't continue and shuts down.
Jun 30, 2014 | AOC 19LVWK LCD Monitor
AOC 2036s shuts off after seconds
my aoc monitor 2036s is blinking when i run hd movie or play game . what can I do for fix my problem. please suggest....
Jan 28, 2012 | AOC Computers & Internet
I JUST PURCHASED A NEW 19INH AOC MONITOR TO USE WITH MY E-MACHINE. IT WORKS FINE EXCEPT IT SHUTS DOWN WHEN I LEAVE THE COMPUTER AND STAYS THAT WAY UNTIL I MANUALLY START IT AGAIN.
Hello Eldon, don't worry this is a safety devise that is built in to your unit and many others. It gives your screen longer life. GOOD LUCK.
Oct 22, 2011 | AOC 931SWL 19 inch Monitor
HI HAVE A NEW AOC COMPUTER MONITOR FROM AOC. IT SHUTS DOWN EVERY TIME I LEAVE IT AND I WOULD LIKE FOR IT TO REMAIN ON ALL DAY LONG AND I WILL SHUT IT DOWN AT NIGHT MANUALLY; HOW CAN I DO THIS. ...
go in to monitor in the control panel and set the sleep mode time mode
probably better if you go into bios setting and click on computer start from any key movement
that way the monitor and computer go into sleep mode and that saves money on power and you only have to move the mouse or press a key and 10 seconds later the screen is awake and the computer is operational
I am typing this looking at an aoc monitor attached to a pc ;
Sep 13, 2017 | AOC 931SWL 19 inch Monitor
My aoc monitor 2216sw shut down after three seconds on
It sounds defective. When the high voltage power units stop working; you will experience this type of problem. I would call AOC and see if the monitor is under warranty. Otherwise, seek an alternative monitor to use.
Jan 06, 2011 | AOC 2216SW Monitor
AOC F22 lcd 22" monitor locked menu button and power button are the same plus when u shut down it doesnt want to come right on
Hold down the power button to turn it off, then hit the power button and immediately hold down the left side of the ring. Wait for the OK to disappear.
Took me a couple tries, but it works.
Apr 06, 2010 | AOC LM742 17" LCD Monitor
Existing Graphics Card Radeon X300, which one to
I have looked it up on the internet, the graphics card is capable of displaying your monitors resolution. I am therefore assuming you want a new graphics card for 3d applications, since 2d is easily rendered by this card.
However, simply replacing the graphics card will not help. You will probably have a hard time finding a card that can fit on your mainboard, and even if you do, your prcessor will not be fast enough to send the required data to the graphics card.
In this case you will have to buy a new PC, I'm sorry. If I did not understand what you meant, please post a comment.
Regards,
Yannick.
Oct 15, 2009 | ATI RADEON X300 SE Graphic Card
Same problem--AOC monitor "goes to sleep" after an hour online
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 09, 2009 | AOC 19LVWK LCD Monitor
No display
Try Unplugging the monitor and plugging back in again,,,you dont have to shut the PC down to do this,,,if it starts backup,,,then good... if it doesnt,,then you need another Monitor.
An LCD monitor is better for your eyes anyway.
Jan 19, 2009 | AOC 1556NB 15"
Hello please help me to solve my problem. my monitor blow the power ic or power transistor. my monitor model are AOC 5 En 15 in.CRT.... now i hope solve my problem because i dont know what value of...
MR. elydon AOC 5 En mostly use this parts IC901 # UC3842AM and Q901 IRFBC40 or K2544 this parts usually use in power supply circuits or visit my email add almer_daxenreplica@yahoo.com
Jul 18, 2008 | AOC 5 En 15" CRT Monitor
Computers & Internet Logo
298 people viewed this question
David Payne
David Payne
