Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a Kenmore 106.56532400 model side by side and it will not produce ice. It has the electronic sensors and the bin is in the door of the unit. I unplugged and the red light came on and stayed on. I checked now and the red light does not come on at all. No water is going into the unit. Before it quit making ice I did notice sometimes that water would be frozen on the bottom of the icemaker as thought it had overflowed.
SOURCE:
ttech
  • 147 Answers
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
I Have a Solution for this Problem,Contact live on line Now ttech
Posted on Jul 21, 2007
fridgetech
  • 473 Answers
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Posted on Nov 07, 2007
  • 42 Answers
SOURCE: kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
Posted on Jan 25, 2008
  • 27 Answers
SOURCE: kenmore indoor icemaker frozen wil not dispense ice
Hi. I need more information to help you with your problem. Model number and a better discription of your problem. Will not come out of the ice maker itself or the ice dispenser? Thanks, Mack
Posted on Mar 23, 2008
You have a better chance of finding out that the problem is a broken moduele. The fingers that grab the ice and rotate it out they should be resting at the 2 oclock posotion. If stuck in any other posotion its broken. It's expensive but not hard to do. If you had a bad soloniod you would either have a frozen tube or a block of ice at the top
Posted on Sep 01, 2008
My kenmore side by side is not producing ice and there is a red light blinking inside the freezer sec
Can you locate your model number inside the fresh food section around door frame? I believe you have the ice maker with the electronic eye and sounds like you need to follow these instructions so the ice maker works again. If I am wrong then please correct me by posting your model number that should look like this example=> 321.234567 Click Here=> Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here if you need to ask questions, Sea Breeze
Nov 30, 2013 | Kenmore Side by Side Refrigerator
106.57029 ice maker intermittent
there is usually an ice overflow switch or electric eye
sensor telling the ice maker that the bin is full. Something
may be obstructing this.
Nov 08, 2013 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Model 106.57789704 - ice wont release into door bin
This probably is not what you wanted to hear but... I recommend you to the human manual defrost method to free things up as a result of the ice that built up post power failure. That somewhat messy method being:
1. Unplug the unit.
2. Remove Freezer contents (You do not need to empty fresh food contents)
3. Place a fan blowing into the freezer section for around 2 hours. (Messy part so be ready to tend to the drips with rags & mop)
AFTER 2 HOURS
4. Take a rag or sponge and remove most of the water out of the ice maker as best as you can after the manual defrost.
5. Completely empty the ice bin of all ice or water paying particular attention to the auger making sure there is no ice at all in the auger.
6. Plug in the unit.
7. Reload Freezer contents.
This should get things back to normal. If not there is much more that can be attempted. At this time I really believe that the above procedures will normalize your unit. If and when you need more assistance just respond here I and I will gladly assist you.
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Kenmore Refrigerators
Will not make ice
The ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 29, 2010 | Whirlpool GS6NBEXR Side by Side...
Kenmore - ice maker won't produce but water in door fine
Most of the times the solenoid ( electric valve that lets water from the line when the ice maker calls for it) leaks and this little water freezes up inside the filling tube for the ice maker , in tnis case the solenoid has to be replaced.
Oct 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Icemaker will not turn on
The very best place to start is with mini manual located inside the kick plate pull it off its the brown/yellow one
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
124 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
