Question about Poulan 18" Wild Thing Chainsaw
I need the carberator settigs for a poulan 40ccwild thing model #p4018wt952802030
  • Poulan Master
  • 2,239 Answers
Base settings are one and a quarter turn on each screw, you will need to fine tune from there, you should not exceed the max rpm 12500, this should be checked with a suitable taco, the idle speed should be 3000/3200 rpm.
Posted on Mar 19, 2011
Poulan-Pro grass trimmer model PPB-150E.I had to feather the trigger to keep it running.Now with the lever in start,the motor lopes. Removed the carberator cover to check for kinked fuel or air lines
Check the fuel filter in the fuel tank, you can hook this out through the filler hole, this should be replaced not cleaned, if you have the tool to adjust the carb then unscrew the L screw a small bit at a time and try again.
May 18, 2018 | Poulan Garden
Poulan pp4218a chainsaw is leaking gas out of the sm hole in top of carberator
if this small hole is in the center of a plate with 4 screws you need a new diaphragm.
Feb 04, 2018 | Poulan Garden
Adj.carberator
if it's new don't touch anything you will void the warranty take it back! what kind mode ,l , #, cc, any thing? there are too many to give answer for all!
Jan 26, 2015 | Poulan Garden
How long should the juel line be on a 40cc poulan
A fuel line should be long enough to teach from where it attaches to the carberator to the fuel tank but not quite touching the bottom - however the line in the tank end should have a small filter on it. You should be able to buy a replacement line for your specific saw.
Dec 11, 2014 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Front tiller diagram of poulan carberator hdf550j
I would need to know the engine make and model. this is independent of the equipment make and model. Looks like it is a B&S, but I can't be sure by tiller model number.
May 30, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I need a service manual for a Poulan 2250 chain saw. I have several questions about this saw. Like the carberator has an in and an out. I need this info. to connect the filter line to the inlet side.
the best and fastest way to get the answer to this question would be to contact Poulan --- there is a ask Poulan website ,, http://poulan.JustAnswer.com/ they can get you the correct info you seek. I wish I could help more,, it has been several years since I owned a Poulan saw ( I am a Stihl guy now ), and I have been where you are right now ( 11 years ago I replaced the fuel line on mine -- it had a crack in the line ).
I hope this helps,
c...
Dec 29, 2010 | Garden
An i find pictures of a carberator for a crafstman
Your saw is made by Poulan.
The IPL (exploded parts list) for your saw contains a breakdown of the carburetor. Until 09/24/09 you could go find an IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Now you must be a dealer to utilize the only known source of parts for your saw. Please register your displeasure with this arrangement here:
http://www.poulanpro.com/node4033.aspx
They should also provide a link to the correct IPL for your saw. HTH
Lou
Sep 27, 2009 | Poulan Garden
Have Poulan 22'' Won't Start
Clean your gas tank start with some fresh gas.
Jul 05, 2009 | Garden
Poulan 18" Wild Thing Chainsaw Logo
322 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
