Question about Welding Tools
Seelye welder doesnt seem to be putting out enough amps.
  • 407 Answers
Hi:
Always the same problem with seelye's. Check your ground cable and if doubts of being well tight the terminals and the ground clamp, change them.
This will take care of the problem.
Posted on Mar 21, 2011
Miller bluestar 6000...generator works great...welding seems stuck on max amps...dial doesnt seem to change amp power...bogs engine..less than 150 hours...ideas???
could be a faulty power control swotch
I am inclined that the voltage regulator the controls the amp out put is faulty
Take it in for a specialist diagnosis to a welder repair shop
Nov 02, 2015 | Miller Welding Tools
Fan on millermatic250 mig welder doesnt stay on all the time should it?
The fan does not run continuously. It only runs when it needs to. It depends on the work load of the welder. Short runs do not cause it to heat up enough to close the contacts for the fan. The longer welds will create the heat in the coil to rise enough to close the contacts and make the fan run.
Mar 05, 2014 | Miller Welding Tools
Spool won't turn
are the rollers tightened enough, also maybe the wire is jammed in gun.
Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Just purchased and tried to use my flux welder. It jams before flux even comes out the handle.
have you tried adjusting the tension on the flux wire? before you start feeding the wire into it make sure there isnt any kinks in the wire. seems like it doesnt take much for it to bind up once you get start welding with it im sure you will run into this problem quite allot. usually its from welding the wire to the tip. i have to be honest it can ve a pain in the ***
Dec 30, 2010 | Firepower Flux Core Wire Feed Welder 88...
Welder will not weld wire comes out will not stick seems not hot enough on low to hot on high
the earthing may be suspect.check & clean the connections otherwise the supply cable may be too long causing a voltage drop!
Nov 23, 2010 | Computers & Internet
Ive got a handler 135 110v - the weld penetration is very poor - using 030 solid wire with 75/25 gas, I have to run the machine at setting 4 to get a half way decent penetration on exhaust tubing, sheet...
This machine is supposed to be hooked up to a 20 amp breaker all alone, with nothing else running off that 20 amp breaker. Also are you using an extension cord? It is usually not recommended to do so, although I have the same machine and it seems to do just fine. Just make sure you are getting proper power to the machine.
Nov 11, 2010 | Hobart Handler 140 Mig Welder
Ranger welder does not generate enough dc current to weld with and only enough current to turn a ac drill very slowly. checked wires seem to be ok.
clean the brush rings with a very fine emery cloth is still then there is a controller board issue at that point it will have to go to a service center do to there are no supplier's for them other that Lincoln go to their sit HERE and find a service center in your area these boards range from $250.00 to $600.00 there is 4 of them in the machine they will have to remove the top and swap the boards till they find the right one have the same welder i have been through this with Lincoln already hope this helps
Aug 09, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Feb 24, 2010 | Welding Tools
Welding Tools Logo
76 people viewed this question
Top Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Welding Tool Expert? Answer questions, earn points and help others
