Question about Lenovo 90W Ultraslim ACDC Combo Adapter USCanada AC Adapter
I have the ultraslim combo ac/dc charger. On the plane, using a standard plug through the power brick, there was no power to the laptop. I tried several different seats with the same result, while other passengers had no problem. The plane did not have a special DC (cigarette lighter type) outlet, just a standard plug. Shouldn't this work? Thanks
  • 1,606 Answers
The plane may have been running 400 Hz. power through the outlet, and your charger's input filter was blocking it so you didn't have enough voltage getting through. The other passengers probably did not have as much inductance (high-frequency filtering) in their stuff.
Posted on Mar 19, 2011
I would like to charge my 930 T on 120 volt A C adapter
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Oct 18, 2015 - Read this guide on finding the right charger or power adapter. ... As part of that process, I took all my power supplies and adapters and threw them into a box. ...from a 120 V AC outlet in your home) and convert it to a specific DC output. ... Voltage is measured in volts (V) and current is measured in amps (A).
Is there a way to charge my 930 T on a wall socket AC adapter
www.fixya.com/.../t26037021-way_charge_930_t_wall_socket_ac_adap...
24 mins ago - is there a way to charge my 930 T on a wall socket AC adapter - PC Laptops ... I would like to charge my 930 T on 120 volt A C adapter. Jan 03 ...
AC versus DC charging - what is the difference? ' Plug In ...
www.pluginamerica.org > Blogs > Drivers Seat
Plug In AmericaOct 13, 2013 - It is simply a USB cable, which allows my tablet to charge from a DC USB ... When you plug in to AC power - whether you plug in to a 120V or .... 120vphone chargers and plugging in to 74 volts DC and charging their phones.
Jan 03, 2016 | Computers & Internet
Troubleshoot no power supply even the charger is connected
What to Do if Your Laptop Is Plugged In but Not Charging ...
www.pcmag.com > Reviews > Laptops & Notebooks
PC MagazineAnd no battery charging. ... but some problems may require a visit to a repair shop oreven a full-blown ... Get ready, boys and girls, it's time to go troubleshooting. ...Check the AC adapter brick and verify that any removable cords are fully ...
Laptop Won't Power On - Troubleshooting a AC/DC Adapter ...
www.ifitjams.com/lappower.htm
Troubleshooting problems where the laptop won't power, adapter LED is off ... When your laptop won't turn on with the AC power adapter plugged in, many ... SOme laptops even feature a power button that lights when the power is turned on.
Sony VAIO® - Some troubleshooting steps to help you if ...
? 2:56
https://www.youtube.com/watch?v=IsbMD-Ddcp0
Feb 3, 2012 - Uploaded by SonyListens
Sony VAIO® - Some troubleshooting steps to help you if your VAIO will not power on. SonyListens ..... I have a VAIO laptop & the AC adapter isn't charging the battery. Help? Oh yeah ... It's as if it isn't even plugged in. I've tried ...
Laptop Won't Come On Even When Connecte
Dec 30, 2015 | Computers & Internet
Do I have a negative battery system or positive battery system?
If you have a 12volt standard electrical system in your vehicle.
It is both positive and negative. The travel inverter converts this 12 volt DC current into 110v 60hz AC current so you can plug in your electronics that require standard household current to charge/operate.
There is a built in USB port if you device will accept this for 12 volt power. It also has the power oultet with ground for 110v 6hz power.
Link below has a good picture and description. Hope this helps!
http://www.sears.com/diehard-120-watt-ultra-slim-travel-inverter-with/p-02871520000P
Dec 30, 2013 | Sears DieHard 120Watt Ultraslim Travel...
What is power brick cord?
An AC adapter, sometimes called a power brick, is a little box that takes the Alternating Current (AC) line voltage from your house receptacle and converts it into a Direct Current (DC) voltage that is used by your electonic device (computer, hard drive, etc.). This power brick sometimes has a separate power cord that is removable from the brick. This cord usually connects to your house receptacle, and sometimes it is a standard cord with standard connectors on each end.
Nov 10, 2013 | Pacific Digital (U30274) DVD±RW...
Can i use this lap top with plug in and not a battery?? where is the plug in?
I BELIEVE so. Some laptops require the Battery to at least be in the laptop, whether they are good, or not.
Others will allow the laptop to run off of the AC adapter (Charger), with the Battery not installed.
Gateway Support > Gateway MD26 series of Notebook PC's > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2364
Click on the - Support Documents - tab.
(Drivers / Applications / BIOS / Patches / Support Documents / etc)
Click on - Product Views - in the list.
Click on - Left View
Power connector
This is where the AC adapter (Charger) plugs in.
Examples, (Note US and Europe have different power plug ends),
http://www.batterytech.com/products.aspx?category=ac_adapter&brand=gateway&model=MD2614U&pid=AC-1990111
[The laptop uses DC electricity. Just like the Battery it has, and flashlight batteries. DC Voltage.
The AC adapter (Charger) converts your household, or business, electricity from AC to DC.
(19 Volts DC. In comparison two D cell flashlight batteries store 3 Volts DC ]
Regards,
joecoolvette
Oct 15, 2012 | Gateway MD2614u Notebook
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
I have an Acer Aspire One and when I plug the charger in I have to spin it or wiggle it or both to get the battery to charge. Once I have it in position it generally stays on charge, but if the cable is...
It could be either one Sarah.
The AC adapter's (Charger) cable, or the DC Power Jack where the AC adapter plugs into the laptop.
This is an example of the DC Power Jack not installed,
http://www.laptopjacks.com/view_part/Acer-Aspire-ONE-AOA150-ZG5-DC-Power-Jack-AC351816.html
(You can click on the three views of the jack to enlarge)
1) Check the DC Power Jack to see if it's in good repair.
Battery removed use a small flat tipped screwdriver, and Gently see if you can move the Center Pin around in the jack.
See if the Center Pin will move side to side a small amount. There is supposed to be No perceptible movement.
Referring back to the closeup photos of the DC Power Jack, the flat blade-like prongs are upside down, in relation to how the jack sits on the motherboard.
The flat prongs go down through the motherboard, and are soldered to the motherboard.
If the center pin of the jack is stationary, but the jack as a unit moves around, one or more solder joints, (Connections) for the flat prongs may be cracked.
The repair consists of completely disassembling the laptop, removing the broken DC Power Jack, and installing a new one.
Acer Aspire One service manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
(Click on the blue - One - in Aspire One.
This is a PDF file. The computer you are using now has Adobe Reader on it which uses PDF files.
After you click on the file name (One) it may take up to 30 seconds before you see the first page.
It may also take additional time for the file to fully download.
(Took 12 seconds just now for full download)
No perceptible movement of the DC Power Jack? Suspect the cable of the AC adapter right near it's plug. (Plug that plugs into the DC Power Jack)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 25, 2011 | Computers & Internet
There is no power to the monitor,it is not coming on when i start up computer
If the AC plugs directly into the monitor, try reseating the power cable or replacing. If the monitor uses a power supply (ac adapter brick) check that the power cable is fully inserted in the brick and the dc connector is fully plugged into the monitor. Also check the dc connector for bent or broken pins.
Mar 24, 2010 | Computers & Internet
My laptop stop charging.
Batteries get old and wear out. Be use AC outlet is working. Check for power light on AC/DC charger box between laptop and AC.
It is common for Laptop charging/power connectors to get worn and/or loose(intermittent). Try to get charging light on PC by wiggling power connection to PC.
If not, if you have a VoltOhmMeter(VOM). check for 5V on barrel power connector on the charger side, that plugs into PC, Outside conductor is GND and Inner connector is (+5V). VOMs are cheap at RadioShack or AutoParts stores and are a handy tool to have around the house. Book shows you how to measure. PC is 120V AC on Wall side of PC Power Supply from Wall Outlet, and 5V DC on PC side of Charger.
Charger may be defective. Cheap on Ebay.
Feb 23, 2009 | Acer Aspire 3680 Laptop
I need the pinout on the AC/DC power plug on the unit.
Here is the circuit I use (I removed the cover and traced the DC pins back to the board, but I haven't tested them yet)
I am using a standard AC cord plugged into the yellow contacts in the drawing, works great.
Jan 13, 2009 | RCA T09082 9 in. TV/VCR Combo
Lenovo 90W Ultraslim ACDC Combo Adapter USCanada AC Adapter Logo
69 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
