Press button, hold to turn on, phillips name comes up then it updates and knocks itself off before I can get any music on it it goes blank
  • Anonymous Sep 04, 2008
    while downloading,suddenly,it turn off by itself.could not on it back.is it the battery problem?do i need to charge it?how long?
    Master:
    Sergeant:
  • 462 Answers
Try to format and also see to it there is charge in the battery.
Posted on Aug 02, 2008
My ipod is disabled
Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod. Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo. Release the buttons. Wait as the iPod resets itself and turns itself back on. Leave the iPod connected to the USB connector so that it can fully charge the battery. Remove the iPod from the USB connector. Navigate to a song using the menu selection and play some music
Mar 24, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod is diabled
I accidentally unplugged my iriver e100 from my computer when it was doing a firmware update. now it stays frozen on the main screen!! Plz help!! D:
on the side of the mp3 player above the lock switch is a very small reset button. it can be pressed using a paper clip, a safety pin, the post of an earring, mechanical pencil led, or something else of similar width and length. press and hold this button until the screen goes blank. it may turn back on itself, or you may need to manually turn it on. it should be fine now.
Aug 29, 2011 | iRiver E100 Digital Media Player
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips gogear sa6185
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 24, 2008 | Philips GoGear HDD075/17 MP3 Player
Nano goes blank
Reboot your Ipod by holding down on the center button while holding down on the menu button.
This should reboot your IPod.
If that doesn't work plug your Ipod into Itunes and restore your software back to factory settings. Make sure that battery if fully charged as well.
Jul 17, 2008 | Apple iPod nano
Frozen solid
i have the same promblem i was listening to my music and it had full batteries and it just shut off this is so bull like i think i have to return it and buy something else!!
May 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Once i turn it on i cant turn it off and when i go to listen to music it just goes and restarts itself
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly...
Thank you
Computerrep
Feb 09, 2008 | SanDisk Sansa e260 MP3 Player
Wont connect
Try using Windows Media Player (version 11 should be fine) to sync music files to it. Using drag-and-drop to the device folder only sometimes works (and usually doesn't).
May 31, 2007 | Philips HDD1630 MP3 Player
42 people viewed this question
 Grubhead
Grubhead
