Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e trash.
  • JerryYall Mar 20, 2011
    Thanks. It is not a parallel port, it is a serial port. How do I check my video card
    President:
  • 2,340 Answers
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Posted on Mar 20, 2011
  • yaoyang Mar 22, 2011
    It depend whether your Graphic card is onboard or using a AGP/PCI Express slot. If your motherboard does not have any AGP/PCI Express Slot you can use the a PCI Graphic card to plug into the PCI slot
    If your monitor works, then most probably your graphic is faulty.
Black screen during startup Acer Aspire L310
Has your monitor worked for it in the past? This may be a stupid question, have you also tried to use your monitor with another computer?
It's possible your graphics controller is out, have you checked the cables insides to see if any wires are bent? Or have you tried to use another cable for the monitor to tower connection?
If you have done all of the above and the monitor works with another computer, it's possible your GPU is out :(
If your GPU is out, you can buy a new one in it's place and it will plug into a PCI slot, chances are your graphics card is integrated.
Do you get any beep codes on the computer? Another odd chance could be the computer itself is actually dead, even if a computer is dead a motherboard can still be active since electricity can still flow through it.
I hope this helps. x: I hope your problem is resolved sooner than later.
Feb 26, 2013 | Acer Aspire L310 Desktop
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
I have a Acer X203H Monitor. Everything is connected I've checked a million times. When my computer turns on it displays fine on the monitor, but the first or sometimes second time the computer goes to...
I would try this monitor with another PC first to verify that it is not PC problem.
Most common failures in the monitors are due to bad caps in the power supply/inverter board, we want to find out first if it is the monitor or the PC problem.
See examples of failed ACER due to bad caps here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Acer X203H Monitor
V193W 19" acer monitor is connected to computer
Hi, Try turning off your system, activate your monitor and then activate your computer. Check the troubleshooting section of the manual received with the monitor and if that still does not help, let me know.
Regards, Icom1
Apr 01, 2011 | Acer V193w LCD Monitor
GRAY BOX SAYS NO SIGNAL AND IT GOES ON AND OFF
The monitor is not getting a video signal from the computer (if it is connected to a computer)
Try the following steps first:
1 Turn off power and disconnect power cables from the computer
2 Press and hold the power button for 30 seconds
3 Reconnect power cables and try to turn it on.
If everything remains same, the next step will be to re-seat memory modules.
Mar 07, 2010 | Acer V193w LCD Monitor
Screen comes on says Acer then No Signal, and goes out. if shut power off and then back on get same result.
This means the monitor believes it's not connected to the computer. Verify the cables first of all. Then try booting in safe mode (F8 key at PC startup) in order to verify that the PC is sending data to the proper video port (you might have a dual VGA / Digital output, for example, and the monitor might be connected to the wrong PC port). Quite often, a "bad signal" will be the same of "no signal"; and you can have a bad signal if the monitor resolution on the PC is set too high. This could happen if you installed a high-resolution capable monitor, and then replaced it with a not-completely-plug-and-play, lower resolution one. The PC would keep sending hi-res signals to a monitor which can neither interpret them, nor tell the PC "please slow down". To check this last possibility, reboot your computer while the monitor is ON. When PCs reboot, they usually drop back to standard VGA signaling, which all monitors understand. If the monitor abruptly comes to life and displays a boot screen, then goes No Signal again after several seconds, you've got a resolution issue; get in Safe Mode with F8 key at boot, and modify the screen properties (right-mouse button on the desktop, then Properties).
If everything else fails, try also connecting the monitor to another PC or laptop, to see if it works there.
Dec 04, 2009 | Acer AL2223W 22" LCD Monitor
Monitor no signal
Your monitor cable is not properly connected to your computer, make sure you have it connected to the correct output on the back of your computer. If it is connected, make sure it is connected securely, not loose and half-cocked at the connector. If that doesn't work, try another cable.
Sep 15, 2009 | Dell E151FPp 15" TFT LCD Flat Panel...
Switching monitors connecting an external monitor
For my Acer 2300.. found in Control Panel an icon for the actuall display card and within there discover Ctrl, Alt -F1 for external, Ctrl Alt -F3 to go back to the notebook monitor. Hope that can help someone.
May 21, 2009 | Acer TravelMate 2300 Notebook
Bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
Computers & Internet Logo
260 people viewed this question
David Payne
David Payne
